QUASI Amplifier for Beginners - Page 71 - diyAudio
Old 17th August 2012, 09:56 AM   #701
olafk is offline olafk  Germany
Default Sorry for bad explanation
The Heatsink should be like the picture. The PCB will be mounted on the backplate of it and the heatsink will be mounted in the enclosure vertical like your intentions.
regards Olaf
Old 17th August 2012, 10:16 AM   #702
djk is offline djk
djk's Avatar
"for 6pair outputs what are the changes to make with 80vdc? "
Change BC546 to 2N5550
Change MJE15030/31 to 32/33
Change 2N3773 to MJ15024
The 22K that feeds the diode pair needs to be 5W, it can be 3W on 65V
The 22K feedback resistor needs to be 1/2W, it can be 1/4W on 65V
Candidates for the Darwin Award should not read this author.
Old 17th August 2012, 05:43 PM   #703
thanks djk for the reply.
Old 22nd August 2012, 11:55 AM   #704
Originally Posted by nazirdigi View Post
apex vu pcb.
hi apex sir,
when i connect the vu meter to ax14 amp, the power light and 2nd and 3rd lights permanently on , why is that?
Old 22nd August 2012, 02:39 PM   #705
Default Hi
and it's size?
Old 27th August 2012, 04:01 PM   #706
bkby is offline bkby  Thailand
Originally Posted by mihailo View Post
Thanks. Will post pictures, when I finish.
Waiting for you.
Old 27th August 2012, 07:37 PM   #707
Default for the meantime...
...better PCB
regards, Olaf
Old 28th August 2012, 04:34 AM   #708
Hi all if I wanted maximum 100W in to 8 oham load what should i have to change in this circuit and what will the supply requirement is 40-0-40 5A ac transformer is OK please replay
Old 28th August 2012, 06:12 AM   #709
Boscoe is offline Boscoe  United Kingdom
Read the thread!!
Audio projects and more: gswdh.co.uk
Old 28th August 2012, 08:53 AM   #710
40+40Vac gives 150W to 170W with a BJT output stage.
I'd expect 120W to 140W with a source follower mosFET output stage. Probably quite a bit more with a common source output stage.
regards Andrew T.
Sent from my desktop computer using a keyboard
How to identify a quasi-complementary amplifier? motbuddy Solid State 52 1st March 2017 07:59 AM
MOSFET/BJT QUASI AMPLIFIER WITH PROTECT!!! apexaudio Solid State 42 18th January 2015 09:22 AM
A.Holton AV400 using irfp or Quasi mosfet amplifier ? medogrizli Solid State 49 5th November 2011 11:04 PM
question about quasi nmos500 amplifier schematic? muky006 Pass Labs 3 8th May 2008 09:07 AM
Quasi N30 ClassA amplifier AndrewT Solid State 8 9th January 2008 07:57 PM
Copyright 1999-2017 diyAudio
