QUASI Amplifier for Beginners
Old 22nd June 2012, 01:07 PM   #671
R.I.P.
Not very well.
Probably badly.
regards Andrew T.
Old 22nd June 2012, 01:27 PM   #672
formula 22 is offline formula 22  El Salvador
formula 22's Avatar
Originally Posted by AndrewT View Post
Not very well.
Probably badly.
Why well not?!
A higher "quiescent current" (about 100mA), audio amplifier goes to the class-AB!
Class-AB less THD distortion, ....
Andrew cheers!
Old 22nd June 2012, 06:37 PM   #673
R.I.P.
No Tempco
ClassB ish
Odd feedback
regards Andrew T.
Old 25th July 2012, 09:02 AM   #674
sudhir kumar is offline sudhir kumar  India
hi Apex sir,
Currently using this amp with 5 pairs of 2n3773,supply 40-0-40 AC 1.5kv traffo,20,000mfd caps per side on 4 ohm load. sounds good to my ears even as full range amp but currently coupled with your 2x12 inch subwoofer enclosure in a three way system.
What output power i should expect from this ?
Old 25th July 2012, 10:13 AM   #675
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Originally Posted by sudhir kumar View Post
hi Apex sir,
250W on 4 ohm load with 40-0-40 AC, can you post pictures of your sub?
Old 7th August 2012, 11:28 AM   #676
olafk is offline olafk  Germany
Default Very hot
I built the amplifier (picture see post #663) with two pairs of 2N3773 and I use +-60V DC. Now the Transistors MJE350/340 become to hot. I can touch them for only 3-4 seconds and I think it is a bit critical.
Should I reduce the voltage (have regulated power supply) or are there any other things I can do? I changed the heatsink to a bigger version for TO220 like the MJE15030, but gave no better result.
Can anybody help me?
regards
Olaf
Old 7th August 2012, 12:56 PM   #677
apexaudio's Avatar
regards
Olaf
Nice work, MJE340/350 work in class A and must be hot but use 100R resistor instead 56R around MJE340 and this will reduce current in VAS CCS and disipation on MJE340/350 also.
Can you share your pcb?
Old 7th August 2012, 01:01 PM   #678
Default Hot
Hi Apex,
thanks for the advice. I will test it after work this evening.
regards
Olaf
Old 7th August 2012, 07:17 PM   #679
Default PCB
Hi Apex,
it works. Thankyou.
Here is PCB.
regards
Olaf
Old 7th August 2012, 07:21 PM   #680
apexaudio's Avatar
Hi Apex,
it works. Thankyou.
Here is PCB.
regards
Olaf
Nice PCB, thank you.
QUASI Amplifier for BeginnersHide this!Advertise here!
How to identify a quasi-complementary amplifier? motbuddy Solid State 53 30th August 2017 08:05 PM
MOSFET/BJT QUASI AMPLIFIER WITH PROTECT!!! apexaudio Solid State 42 18th January 2015 09:22 AM
A.Holton AV400 using irfp or Quasi mosfet amplifier ? medogrizli Solid State 49 5th November 2011 11:04 PM
question about quasi nmos500 amplifier schematic? muky006 Pass Labs 3 8th May 2008 09:07 AM
Quasi N30 ClassA amplifier AndrewT Solid State 8 9th January 2008 07:57 PM
