QUASI Amplifier for Beginners - Page 66 - diyAudio
Old 17th June 2012, 04:26 AM   #651
t68kv is offline t68kv  Philippines
Components are already specified in the top view and schematics posted at page 1.
As for capacitors, use 50V for input stages and 250V or above for VAS, driver and output stage (100nf and 470pf).
Old 17th June 2012, 04:50 AM   #652
yehan is offline yehan  Philippines
Thanks. My concern about the capacitor where the ceramic or mylar? And only 65+- volts dc maximum? When i put 80+- it is ok and add more output transistor?
Old 17th June 2012, 05:07 AM   #653
djk is offline djk
djk's Avatar
"When i put 80+- it is ok and add more output transistor? "
Only if you can hand-select the outputs to be sure of a higher voltage than what the part is rated for. For instance, Crown hand-selects all the 160 outputs used in the MA10K to run at 163V (rail-to-rail), plus a safety margin for high line-voltage.
Candidates for the Darwin Award should not read this author.
Old 17th June 2012, 09:23 AM   #654
Thanks djk..
Old 17th June 2012, 11:46 AM   #655
Helllp...which mylar capacitor or ceramic capacitor..thanks..
Old 17th June 2012, 11:51 AM   #656
Default mylar and ceramic....
capacitor that have values expressed in uf are mylar and pf is for ceramic.
regards,
drowranger
Old 17th June 2012, 11:57 AM   #657
Can used darlinton instead of 2sa1943 and 2sc5200? To prevent the heat sink long? Thanks
Old 17th June 2012, 12:12 PM   #658
Default stick on the circuit...
darlington and paralleled ouput are not the same configuration.
regards,
drowranger
Old 17th June 2012, 12:22 PM   #659
Ok....thanks...
Drowrenger..do you make this amp? How much supply for maximum +- dc.
And the watts how much? This circuit produce 500 watts rms?
Old 17th June 2012, 12:28 PM   #660
Default not yet....
Ok....thanks...
better wait for apex reply about the supply and how much wattage it can produce..
regards,
joel
How to identify a quasi-complementary amplifier? motbuddy Solid State 52 1st March 2017 07:59 AM
MOSFET/BJT QUASI AMPLIFIER WITH PROTECT!!! apexaudio Solid State 42 18th January 2015 09:22 AM
A.Holton AV400 using irfp or Quasi mosfet amplifier ? medogrizli Solid State 49 5th November 2011 11:04 PM
question about quasi nmos500 amplifier schematic? muky006 Pass Labs 3 8th May 2008 09:07 AM
Quasi N30 ClassA amplifier AndrewT Solid State 8 9th January 2008 07:57 PM
Copyright 1999-2017 diyAudio
