#581 |
#582 |
If you want PNP outputs, you must revert rail polarity, diodes polarity and all transistors must be pnp instead npn and vice versa.
http://apexaudio.rs/ |
#583 |
#584 |
not correct.
you have used the PSU Zero Volts (between the capacitors) as an Audio Ground. no no. you have swapped the +ve & -ve supplies. you have no emitter resistors in the emitter leads of the four leftmost output devices. no no. you have the mains fuse and the mains switch in the two different Mains Lines. no no. Last edited by AndrewT; 27th March 2012 at 02:49 PM. |
#585 |
@andrewT sir kindly corect the wrongs ones because i can't get what you mean plss...
regards |
#586 |
Hi people!
Where the schematics of this quasi amplifier, as one friend told me that she is wrong? ![]() ![]() Cheers! |
#587 |
post number 1 page 1
#588 |
Hi
Need to add a resistor of 0.33ohm/5W on the transistor 2N3773 or 2SC2922 (for Ucc=+/-70V) in the emitter of the negative branch of power supply. Ceers !
#589 |
Hi there
i want to use apex550 @ 2 ohm. what should be the optimum rail voltage.i mean i want 400 watts @ 2 ohm 800 watts @ 4 ohm (bridged) mono is it possible? thanks in advance
#590 |
400W into 2r0 is equivalent to 40Vpk and 10Apk into your 2r0 load.
Expect +-50Vdc to be suitable. Two amplifiers from the same PSU will require ~60Apk transient current demand. Design for that 60Apk, or you won't get decent performance from the speakers. |
| MOSFET/BJT QUASI AMPLIFIER WITH PROTECT!!! | apexaudio | Solid State | 40 | 21st November 2012 01:37 PM |
| A.Holton AV400 using irfp or Quasi mosfet amplifier ? | medogrizli | Solid State | 49 | 5th November 2011 11:04 PM |
| How to identify a quasi-complementary amplifier? | motbuddy | Solid State | 8 | 24th April 2011 11:59 AM |
| question about quasi nmos500 amplifier schematic? | muky006 | Pass Labs | 3 | 8th May 2008 09:07 AM |
| Quasi N30 ClassA amplifier | AndrewT | Solid State | 8 | 9th January 2008 07:57 PM |
