Old 2nd February 2012, 03:59 PM   #531
Send a message via Yahoo to AudioSenseCD
@ apex sir do you have a pcb design, placement parts ,layout TY...
and sir what is the other final predrivers for mje15031/30?
regards
Old 2nd February 2012, 10:04 PM   #532
@apex sir i got an alternative for mje 15031/30
a1941/c5198
datasheet
Technical/Catalog Information 2SA1941-O(Q,T)
Vendor Toshiba
Category Discrete Semiconductor Products
Transistor Type PNP
Voltage - Collector Emitter Breakdown (Max) 140V
Current - Collector (Ic) (Max) 10A
Power - Max 100W
DC Current Gain (hFE) (Min) @ Ic, Vce 80 @ 1A, 5V
Vce Saturation (Max) @ Ib, Ic 2V @ 700mA, 7A
Frequency - Transition 30MHz
Current - Collector Cutoff (Max) -
Mounting Type Through Hole
Package / Case TO-3P-3, SC-65-3
Packaging Tube
Lead Free Status Lead Free
RoHS Status RoHS Compliant
Other Names 2SA1941 O Q,T
2SA1941OQ,T
Datasheets 2SC5198
Standard Package 50
Family Transistors (BJT) - Single
Series -
Transistor Type NPN
Power - Max 100W
Supplier Device Package TO-3P(N)
Packaging Tube
Old 2nd February 2012, 10:39 PM   #533
mihailo is offline mihailo  Serbia
You can also use 2SC2073/2SA940 ( 150W 1,5A 20W ) instead of MJE15030/31. I had used it in AX-14 Apex project, and it works nice. Its very cheap transistor. You can find it in tv services.
Old 3rd February 2012, 07:23 AM   #534
djk is offline djk
djk's Avatar
AudioSenseCD, I like your idea of the TO-3P driver transistors.
Candidates for the Darwin Award should not read this author.
Old 3rd February 2012, 11:34 AM   #535
@jdk thank you sir for compliments i will gladly help....
@mihailo hard to find in my area sir and i greatly study the drivers and predrivers so i got stock of 2cs5198 & 2sa1941 and i use both i hope it will help others
regards
Old 3rd February 2012, 12:16 PM   #536
still going....
please enlighten me master 's of diyaudio
Old 3rd February 2012, 07:08 PM   #537
apexaudio's Avatar
Nice progres.
Pcb from post #1 have mistake, check your pcb.
Old 3rd February 2012, 07:11 PM   #538
apexaudio's Avatar
TO220 (TIP41C/42C) and TO126 (MJE340/350) have different (revert BCE-ECB) pins.
Old 3rd February 2012, 10:44 PM   #539
yes sir i already cut the line and jump thx again for info about tip
Old 3rd February 2012, 11:24 PM   #540
djk is offline djk
djk's Avatar
You cannot use the TIP41C/42C to replace the MJE340/350 unless the rails are under ±50V.
Also, the TIP are 3Mhz parts vs the MJE are 15Mhz~60Mhz (depending on the operating current).
A.Holton AV400 using irfp or Quasi mosfet amplifier ? medogrizli Solid State 49 5th November 2011 11:04 PM
How to identify a quasi-complementary amplifier? motbuddy Solid State 8 24th April 2011 11:59 AM
MOSFET/BJT QUASI AMPLIFIER WITH PROTECT!!! apexaudio Solid State 39 2nd March 2011 08:58 AM
question about quasi nmos500 amplifier schematic? muky006 Pass Labs 3 8th May 2008 09:07 AM
Quasi N30 ClassA amplifier AndrewT Solid State 8 9th January 2008 07:57 PM
Page generated in 0.12569 seconds (52.16% PHP - 47.84% MySQL) with 11 queries
