QUASI Amplifier for Beginners
Old 20th November 2010, 07:28 AM   #231
djk is offline djk
R.I.P
djk's Avatar
"for +-75 to 80v any substitute for mje15032/33? "
That's a pretty good part, and it shouldn't be too hard to find.
The NJW 0281/0302 would make a good substitute. The ON Semi price reference is $0.93 vs $0.61 for the MJE 15032/33.
http://www.onsemi.com/pub_link/Collateral/NJW0281-D.PDF
Candidates for the Darwin Award should not read this author.
Old 20th November 2010, 09:50 AM   #232
R.I.P.
post228 will not be reliable with +-65Vdc.
Most of the transistors are the wrong type or wrong voltage rating.
The maximum voltage I would recommend is +-40Vdc.
regards Andrew T.
Old 20th November 2010, 11:04 AM   #233
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Originally Posted by djk View Post
I don't think the BD139/140 are rated at high enough voltage to work at 65V, nor are the TIP 41C/42C.
Yes, but with MJEs will work at +/-65V, only I suggest 2N5551 instead BC546.
Old 20th November 2010, 11:29 AM   #234
R.I.P.
MJE350 are not the correct type for VAS duty.
regards Andrew T.
Old 20th November 2010, 12:42 PM   #235
echobase is offline echobase  Malaysia
Yap! you're right. it is 40V to be precise. Thanks for correcting.
Best regard
Old 20th November 2010, 01:25 PM   #236
djk is offline djk
R.I.P
djk's Avatar
"MJE350 are not the correct type for VAS duty. "
Sure, there are better types. Consider that it speeds up to 60Mhz around 20mA (use a heatsink), it may be adequate for this type of amplifier.
Old 20th November 2010, 01:44 PM   #237
boytaho is offline boytaho  Philippines
Default driver
what do you think is the suitable driver for this amp on this site???
Crown - The Professional Choice
any suggestions?
Old 20th November 2010, 02:02 PM   #238
djk is offline djk
R.I.P
djk's Avatar
No T/S parameters that I can see.
Old 21st November 2010, 06:47 AM   #239
noobie is offline noobie  Philippines
noobie's Avatar
Default pnp output
Originally Posted by apexaudio View Post
Do You want QUASI PNP output stage?
care to share your quasi pnp output.
thanks
Old 21st November 2010, 11:53 AM   #240
apexaudio's Avatar
thanks
You can use same circuit for quasi pnp output, just replace all pnp transistors with npn and all npn replace with pnp, revert diode polarity and use revert +/- rail voltage polarity and you get quasi pnp amp.
QUASI Amplifier for BeginnersHide this!Advertise here!
How to identify a quasi-complementary amplifier? motbuddy Solid State 53 30th August 2017 08:05 PM
MOSFET/BJT QUASI AMPLIFIER WITH PROTECT!!! apexaudio Solid State 42 18th January 2015 09:22 AM
A.Holton AV400 using irfp or Quasi mosfet amplifier ? medogrizli Solid State 49 5th November 2011 11:04 PM
question about quasi nmos500 amplifier schematic? muky006 Pass Labs 3 8th May 2008 09:07 AM
Quasi N30 ClassA amplifier AndrewT Solid State 8 9th January 2008 07:57 PM
