Old 19th November 2010, 02:16 PM   #221
A square's Avatar
Send a message via Yahoo to A square
hello sir ...
pls tel me how can i add clip led in my amp..??
jon
Old 19th November 2010, 03:36 PM   #222
tantang is offline tantang  Indonesia
Hello Mr APEX, i have many transistors PNP. What can be able modfication from emitor follower to colector fllwr this final.....???
Old 19th November 2010, 05:03 PM   #223
apexaudio's Avatar
Originally Posted by A square View Post
hello sir ...
Use this circuit
Old 19th November 2010, 05:07 PM   #224
apexaudio's Avatar
Do You want QUASI PNP output stage?
Old 19th November 2010, 06:09 PM   #225
sanju21 is offline sanju21  India
thanks for the amplifier schematics. i am new to building amps.i have some queries
1 what are the rail voltages for driving 2 ohm load & using 4 pairs of o/p transistors per channel.what else i have to change.( i will be bridging two such channels to drive 4 ohm load ).
2. what will be resulting power in bridge mode when driving 4 ohm load
plz look at this link
http://www.electronica-pt.com/circuitos/en/audio-amplifiers/44-audio-amplifier-90-100w-with-2n3773.html
3. is the above ckt class b or class ab?
4. what is the differnce in qualitywise between the above design & ur design
plz dont be offended i am only a mechanical engineer
please reply to all my queries
Old 20th November 2010, 02:42 AM   #226
The schematic that you mentioned, I did it and it goes out into smoke. I check and recheck with the schematic and the PCB layout, but is just didn't work. Try it for yourself! maybe you could get it right!
Best regard
Albert
Old 20th November 2010, 02:47 AM   #227
I am now in the process of the making of the amplifier that shown in post #1. I'll post the result soon.
Albert
Old 20th November 2010, 03:56 AM   #228
Default Is my bad
Is my bad not to include the images. So these are the images:
Old 20th November 2010, 06:50 AM   #229
djk is offline djk
djk's Avatar
I don't think the BD139/140 are rated at high enough voltage to work at ±65V, nor are the TIP 41C/42C.
Candidates for the Darwin Award should not read this author.
Old 20th November 2010, 06:57 AM   #230
noobie is offline noobie  Philippines
noobie's Avatar
Default mje15032/33=TIP???
for +-75 to 80v any substitute for mje15032/33?
MOSFET/BJT QUASI AMPLIFIER WITH PROTECT!!! apexaudio Solid State 40 21st November 2012 01:37 PM
A.Holton AV400 using irfp or Quasi mosfet amplifier ? medogrizli Solid State 49 5th November 2011 11:04 PM
How to identify a quasi-complementary amplifier? motbuddy Solid State 8 24th April 2011 11:59 AM
question about quasi nmos500 amplifier schematic? muky006 Pass Labs 3 8th May 2008 09:07 AM
Quasi N30 ClassA amplifier AndrewT Solid State 8 9th January 2008 07:57 PM
Copyright ©1999-2013 diyAudio
