QUASI Amplifier for Beginners - Page 13 - diyAudio
Old 1st August 2010, 01:41 PM   #121
apexaudio's Avatar
Originally Posted by eesbiboi View Post
ok...i guess i'd be keeping this one for future use...
one more thing,
how do i know that an amp is capable of running in bridge mode???...coz there are some that say not all amps can run on this mode...
or they can but not for too long...
With this bridge buffer you can use any two identical amps in bridge, only minimal speaker impedance must be doubled.
Old 1st August 2010, 01:47 PM   #122
andrewlebon's Avatar
hi eesbiboi
greetings well i bridged amplifier from eaustralia 300 watts per channel 8 output transistors 2n3773 put more outputs bigger heatsinks 8 0hms load i use it in 4 ohms
works well built it 23 years ago still works
thanking you
andrew lebon
Old 1st August 2010, 01:48 PM   #123
eesbiboi's Avatar
ok tnx sir...
i can make my own pcb design with this one,...
but i'd like to carry your pcb design on it...can you post your pcb for this one sir???...
tnx...
Old 1st August 2010, 01:52 PM   #124
eesbiboi's Avatar
Originally Posted by andrewlebon View Post
hi eesbiboi
thanking you
andrew lebon
very nice... it was really long time ago...i guess i was still -2yr old back then...
for maximum stability and safety operation then i must add more power and a bigger heatsink for the amp...
Old 1st August 2010, 02:01 PM   #125
apexaudio's Avatar
ok tnx sir...
tnx...
This bridge buffer I use on pcb from post #1 in thread: Amplifier motherboard
there are stereo/bridge switch and balanced input, you must design your own pcb if you want use only bridge circuit.
Old 1st August 2010, 02:10 PM   #126
eesbiboi's Avatar
ok i'll have my design on this...
thank you sir...
regards...
Old 11th August 2010, 01:46 PM   #127
Quasi complementary amplifier based on old Dynacord. For begginers Class B without adjust.
Does this amp work? I felt a bit scepticle about amp posted online , non of them really work! I do hope this one work as you claimed? Tempted me Mr.! Hope to hear from you!
Best regard
Malaysian DIY
Old 11th August 2010, 02:16 PM   #128
apexaudio's Avatar
Best regard
Malaysian DIY
This is fully working design.
Old 13th August 2010, 09:42 AM   #129
comasus is offline comasus  India
Hello sir
can i use this amplifier for keyboard and guitar (100watt 8ohms load)
does it work for continues program with two 2n3773
i have 35-0-35 transformer can i use for this amplifier
i found a circuit in the web but it did not worked to me output transistors are getting very hot even at medium sound (see attachment) hope yours will run cool
please attach a fresh schematic with bias adjusting with modifications as per my requirement
sorry for my bad English
Old 13th August 2010, 10:12 AM   #130
apexaudio's Avatar
Originally Posted by comasus View Post
Hello sir
You can use this amp for keyboard and guitar, and it will work with 35-0-35 transformer with two 2N3773 on 8ohms load. Amplifier run cool at medium sound. There is no fresh schematic.
How to identify a quasi-complementary amplifier? motbuddy Solid State 52 1st March 2017 07:59 AM
MOSFET/BJT QUASI AMPLIFIER WITH PROTECT!!! apexaudio Solid State 42 18th January 2015 09:22 AM
A.Holton AV400 using irfp or Quasi mosfet amplifier ? medogrizli Solid State 49 5th November 2011 11:04 PM
question about quasi nmos500 amplifier schematic? muky006 Pass Labs 3 8th May 2008 09:07 AM
Quasi N30 ClassA amplifier AndrewT Solid State 8 9th January 2008 07:57 PM
Copyright 1999-2017 diyAudio
