Location: Where the world's best tea come from:Kericho Kenya
am planning to build a 300 watts mosfet power amplifier,it requires a +/-85 volts symmetric power supply.I've never built a symmetrical power supply before,i recently leart of the simple symmetric power supply consisting of a center tapped transformer,a bridge rectifier and two filter capacitors. My question is:is this setup suitable for a 300 watts power amplifier or does it need some sort of regulation?If so,what power supply schematic would be appriate for this amplifier? Thanks.
if there are no sparks,it probably doesn't work! |
#2 |
Most solid state amplifiers dont need any regulation.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#3 | |
Power amp under development Quasi was starting this thread in 2004 6 years later its a Professional AMP with a lot of features and this MOSFET amp sound really great have designed PCB 237 x 80 mm and add to the original QUASI Design some improvement and features for the DIY community +/- 85V you can get up to 1000W @ 2 ohm look attachments Last edited by qsa; 22nd May 2010 at 09:02 PM. |
#4 |
Thanks Nigelwright,so you mean the simple circuit is ok for the power supply?
| Negative volts and grounding in bench power supply | falcott | Parts | 11 | 29th April 2011 03:42 PM |
| how to use 30 volts DC instead of split power Supply | ali_moinuddin | Pass Labs | 5 | 2nd April 2008 10:34 PM |
| power supply question.... too many Volts? | akimball442 | Tubes / Valves | 3 | 18th February 2007 04:12 PM |
| 16 volts 3A regulated power supply help | sunny | Power Supplies | 30 | 2nd November 2006 11:51 PM |
| Volts AC rating in power supply caps | rick57 | Tubes / Valves | 6 | 28th May 2006 12:59 AM |
| Page generated in 0.09993 seconds (71.99% PHP - 28.01% MySQL) with 11 queries |
