Optical Attenuator/switches... any one ever even seen these. Opto isolated FETs
Old 22nd May 2010, 05:54 PM   #11
krachkiste is offline krachkiste  Germany
there is actually a "driver" IC (also from the panasonic phomos series) that enables you to build an optically isolatet FET relay out of the discrete FETs of your choice.
(http://pewa.panasonic.com/pcsd/produ...pdf/mosfet.pdf)
I stumbled over it recently in this thread:
http://www.diyaudio.com/forums/solid...ion-ready.html
hope I'm not telling old stories
regards,
krachkiste
Old 23rd May 2010, 06:21 AM   #12
Mooly's Avatar
regards,
krachkiste
Not at all... that looks the perfect (never perfect is it ) missing link for a project of mine... DC offset protection without the normal integrator delay.
Relays are the weak point (speed and contact arcing)... so using FET's and a photo voltaic driver could be ideal.
Optical Attenuator/switches... any one ever even seen these. Opto isolated FETsHide this!Advertise here!
FETs used as on/off switches to signal path akis Solid State 12 6th July 2009 03:43 PM
25-position switched attenuator using a pair of 5-position switches? ray_moth Tubes / Valves 1 4th May 2008 08:02 AM
stepped attenuator w/ analog switches ML 32 reference jbraas Analog Line Level 0 19th December 2006 04:00 PM
Dip switches for the attenuator? mgmopar Parts 7 8th September 2004 01:24 AM
Cheap source/step'd-attenuator switches: GrahamnDodder Chip Amps 27 8th February 2004 05:08 PM
