Old 21st May 2010, 09:24 AM   #1
Arnulf is offline Arnulf  Europe
Default PP buffer question
Hi guys,
I don't usually do SS stuff but the need has arisen for output buffer (to replace OPT and to be coupled to triode gain stage, no feedback loop in the amplifier so capacitor coupling at input and output). Goals are:
- simple (few, easy to find parts)
- somewhere in the neighbourhood of 20-30W out into 8R
- negliible load on VAS (so it can drive multiple output stages in parallel)
- be idiot proof
Below is the easiest schematic I could come up with. CCS LED is power indicator and is shared among all output stages (drawn here for the sake of completeness only).
Any comments or alternative suggestions would be greatly appreciated.
Few questions:
1: Transistor choices, sane or not ?
2: T1 and T2 shouldn't be on same heatsink as other three transistors, correct ?
3: Output protection diodes (to supply rails), needed or not ?
4: Output emitter resistors, how to size them resistance-wise ?
5: Any ideas for powerup "thump" elimination ?
mod verb, transitive /mod/ to state that one is utterly clueless about the operation of device to be "modded" and into "fixing" things that are not broken; "My new amplifier sounds great so I want to mod it."
Old 21st May 2010, 01:57 PM   #2
Gordy is offline Gordy  United Kingdom
I do not know enough to comment on your posted design, so here are a couple of alternatives:
FirstWatt / Nelson Pass F4 is an output buffer
Wim de Hann has some projects with tube + buffer at Wim's DIY Audio Projects
Example 1: Mugen hybrid amplifier
Circuit: http://www.wimdehaan.nl/images/mugencircuit.jpg
Example 2: Nishiki hybrid amplifier
Circuit (on page 10): http://www.wimdehaan.nl/downloads/te...lnishiki41.pdf
Old 21st May 2010, 02:11 PM   #3
Thanks for the links. This author went with tubey follower (I want it simple so it will be suitable project for beginners, cathode follower is waste of one tube in this case). It appears diodes (question 3) are a good idea afterall
They did remind me of something I forgot: driver transistors - unless I want to cook T1 and T2 they won't be able to supply enough current for worst case beta of output devices, correct ?
Old 22nd May 2010, 06:57 PM   #4
One very simple possibility is the pass "Zen Variations - Part 5". It is a Push-Pull buffer that can do 20+ W. Not super high specifications on paper, but should work nicely in the real world!
Old 24th May 2010, 04:47 PM   #5
I would like to use bipolar devices, not MOSFETs. This is what I've come up with now:
Output transistors + drivers were replaced by single package darlingtons
CCS sinks ~10 mA for input follower to work into
I still haven't figured out what value of C1 (Vbe multiplier capacitor) to select. Any hints ?
I am still looking for comments regarding the schematic
Old 24th May 2010, 10:41 PM   #6
jcx is offline jcx  United States
Default I don't do tube circuits but maybe this would work
current mirror/level shift/divider will have low distortion compared to a SE tube output
power chip amp is about as simple as it gets
can parallel as many as you want from the 500 Ohm gnd referenced divider output R4
PP question - best driver stage! andyjevans Tubes / Valves 23 1st November 2010 10:33 AM
Buffer question? Dxvideo Tubes / Valves 27 20th November 2009 12:50 PM
B-1 buffer question dyohn Pass Labs 5 1st June 2009 06:18 PM
Tubelab PP question exeric Tubes / Valves 0 18th June 2008 09:29 AM
One more buffer question... Adam M. Chip Amps 18 20th April 2004 01:06 PM
Page generated in 0.12642 seconds (59.67% PHP - 40.33% MySQL) with 11 queries
