Old 19th May 2010, 09:47 AM   #1
bobcat is offline bobcat  United Kingdom
Default Transistor substitutes
Hi all i have managed to locate a schematic for my stageline sta 750 from this forum & thanks,
but iam unable to locate some of the transistors from my usual suppliers
so was hoping that some kind person out there
could help with some substitutes
they are
2sd667
2sb647
2sc1815
2sa1837
2sc4793
2sd669a
all assistance is greatly appreciated
also can someone suggest a good semiconductor equivalent book available in the uk.
regards Bobcat
Old 19th May 2010, 11:26 AM   #2
Mooly's Avatar
Well this is good for most data sheets,
Datasheet catalog for integrated circuits, diodes, triacs, and other semiconductors, view
As to books... T.D. Towers was the one to have.
Amazon.co.uk: towers transistor selector
don't know the last edition though and the web has kind of made all these obsolete.
2sd667/2sb647 are complementary pair... can't think of anything common in that package as equivalents, you will have to search the catalogues. MJE340/350 are a common choice TO126 package but only 0.5 amp rating... is it enough for your application ?
2SC1815 is general purpose... they are in everything and should be easily available, BC546 is fine, as is 2N5551 etc, but the pinouts are different. Anything will work for these as long as it's rated similarly.
2SA1837/2SC4793 are another complementary pair... high voltage TO220 package. Can't think of anything similar off hand.
2SD669... again is 0.5 amp enough... MJE 340 again.
I'll have a think
A simulation free zone. Design it, build it, test it.
Old 19th May 2010, 02:24 PM   #3
AndrewT is online now AndrewT  Scotland
2sd669ac is a 1.5A device with hFE>100 @ Ic=150mA and 20W <=40Vce
You will struggle to source an equivalent. Which parameters are absolutely necessary and which can be relaxed?
regards Andrew T.
Thershold transistor equivalents/substitutes Nickolas K. Solid State 3 1st July 2006 02:02 PM
transistor substitutes mr l Solid State 0 20th December 2004 11:49 PM
Hiraga Transistor Substitutes NickC Solid State 7 7th April 2004 12:32 AM
transistor substitutes biff584 Solid State 6 8th November 2002 09:54 PM
Transistor substitutes Vivek Solid State 0 8th October 2001 08:24 AM
Page generated in 0.10825 seconds (55.82% PHP - 44.18% MySQL) with 10 queries
