Old 19th May 2010, 02:15 AM   #1
Default What type of integrated amp is this please.
Hello Forum:
I have a picture of the internals of a YBA Integre.
From looking at it from my inexperience, I don't recognize a transistor output section or heat-sinks - although I am sure that there are
Could someone comment on the internals and perhaps the over-all design and sonic qualities?
Old 19th May 2010, 02:41 AM   #2
frugal-phile(tm)
planet10's Avatar
Output devices hi-lited. Chassis is the heat-sink
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 19th May 2010, 08:07 AM   #3
Nrik is offline Nrik  Denmark
...heatsink highlighted red - a sheet of aluminium bended two times
STOP - Hammertime!
Old 19th May 2010, 08:09 AM   #4
sakis is offline sakis  Greece
sakis's Avatar
beyond that looks like an excellent made machine .... dont expect loads of power but yeap it looks very fine
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 19th May 2010, 11:36 AM   #5
Thanks to all for drawing those sections for me, such excellent help on this site!
I'm going to do some more search on this unit, but so far it is stated to put out:
50 watts at 8 ohms and
90 watts at 4 ohms using Class Alpha Amplification.
Is Class Alpha similar to or the same as Class A?
It would seem a rather small heat sink assembly for Class A...no?
Also, this unit is five years old and spent its life on the east coast of Florida - although in an air conditioned home. Is this a possible issue with the components?
Old 19th May 2010, 11:46 AM   #6
sakis's Avatar
can be an issue ...but looking at the all set up size of trafo cooling facilities it doesnt look like real Class A equipment ...
it is probably a normal class AB amplifier only instead of 30-50ma that is the normal bias for a comercial amplifier this one is probably biased at 120-300 ma to come closer to class A but not pure class A
that doesnt mean that this a bad amplifier on the contrary it can be a very nice amp ...looking ata the quality of material and the quality of built i think that is a superb piece of equipment
regards sakis
Old 19th May 2010, 11:49 AM   #7
Mooly's Avatar
50 watts in pure Class A would require a much much larger heatsink and PSU.
It's probably some "marketing speak" for a sliding bias class ab or something like that.
Amplifier classes are well defined... either it is or it isn't
Just out of interest what are the device numbers on the output transistors ?
A simulation free zone. Design it, build it, test it.
Old 19th May 2010, 12:02 PM   #8
I don't know what the device numbers for output transistors are. I might be able to find out and will reply.
Old 19th May 2010, 12:05 PM   #9
Mooly's Avatar
Don't worry... I only meant the numbers printed on the top of the those transistors on the heatsink.
Sometimes manufacturers rub them out and paint them over.
They don't like you knowing they used TIP3055 etc
Old 20th May 2010, 09:38 AM   #10
tiefbassuebertr's Avatar
dave
great similarity to Densen's integrated amps:
Densen amp
for normal home hifi applications in Class AB enough (idle current <100mA/channel).
Are there schematics from this YBA model?
JBL SA600 &amp; SA660 integrated 2 ch amps basenjifan Analogue Source 6 2nd January 2012 04:52 PM
changing an integrated tube amp to a power amp f1802llk Tubes / Valves 8 10th October 2008 05:25 PM
Seperate power supply for pre-amp section in integrated amp? KevinLee Solid State 8 2nd February 2008 10:20 PM
Re : BL type &amp; GR type of transistor for Aleph-Ono Arion Pass Labs 4 29th January 2007 06:15 PM
Page generated in 0.15216 seconds (62.61% PHP - 37.39% MySQL) with 11 queries
