after triying to fix a SAE C3A integrated amp i have got to the conclusion that its a tough dog problem and i will like to do this, take out the power amp board an retrofit it whit an stereo module amp.i will like to use the original power supply,preamp,power meters,knobs,switches,volume control,etc. i will like to replace is the power amp section. i will like to have at least 60 to 100 wats at 8 ohms. can you guys please advice on a good amp module and what i need to do the project. thanks.
#2 |
There are loads of modules on ebay.
Unless you want to build your own ?
http://www.murtonpikesystems.co.uk PCBCAD50 pcb design software. |
#3 |
what is your problem with the sae ??? or is it canibalized beyond repair ?? it might be still possible to repair ...these used to be nice amps ////
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
#4 |
no its not canibalized, its just that the right channel does not work.it keep blowing fuses and burns the right channel output transistors. i have the skematic and service manual.but kind of tired triying to find whats wrong. i just want to have the old school look and funcionability of the amp whit new guts. but if you have an idea of what could be wrong its welcome,thanks
#5 |
upload schematic pictures and so on and you can have my opinion
#6 |
here you go
#7 |
there is no schematic of the power amplifier but normaly amplifiers of this range will not be more than 5 minutes to repair .... post a schamtic of the power amplifier and i will let you know a few things about the procedure
| SAE Components | Marc S | Swap Meet | 8 | 10th November 2012 10:50 AM |
| SAE C3A output transistor order | quilla333 | Solid State | 0 | 9th February 2010 05:16 AM |
| SAE C3A blows fuses | quilla333 | Solid State | 6 | 26th January 2010 11:44 PM |
| SAE schematic | Original Burnedfingers | Solid State | 21 | 12th March 2008 10:24 PM |
| SAE schematics | drfeltbetr | Solid State | 2 | 16th March 2004 08:39 AM |
