Sugestions needed on power amp schematics to fit these MOSFETs.
Old 18th May 2010, 07:55 PM   #1
smartx21 is offline smartx21  Brazil
Send a message via MSN to smartx21 Sugestions needed on power amp schematics to fit these MOSFETs.
Default Sugestions needed on power amp schematics to fit these MOSFETs.
I have got some samples of these MOSFETs:
1) Infineon SPW47N60C2 (600V, 47A, 0.07 ohms, COOL MOS POWER TRANSISTOR)
2) Infineon SPW20N60C3 (650V, 20.7A, 0.19 ohms, COOL MOS POWER TRANSISTOR)
3) Microsemi (APT) 1201R2BLL (not sure: 1200V, 12A, 1.25 ohms, POWER MOS7 FREDFET)
I thought of trying them with Legend Stage models.
Any input?
Thanks.
Max.
Old 18th May 2010, 10:14 PM   #2
Nico Ras is offline Nico Ras  South Africa
Nico Ras's Avatar
From the part number, both Infineon devices seem to be N channel, thus you would want to look at designs using a quasi complimentary output.
Old 18th May 2010, 10:19 PM   #3
jaycee is offline jaycee  United Kingdom
These are most likely all switching MOSFETs made for switchmode supplies. I'm not sure if they would be usable in a linear application such as a Class AB amp. They would certainly work, but might give poor results.
Old 19th May 2010, 12:00 AM   #4
Default Feedback from Michael (NMOS amp)
I got this feedback from Michael, about N-MOS amp:
"for NMOS you can use any N Channel Power Mosfet, it will be working without any problems...its not class D...."
Thanks.
Max.
Old 19th May 2010, 12:13 AM   #5
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
I have designed a few amps both quasi and complimentary with switching MOSFETs and had very good results.
PCBCAD51 pcb design software. 2018 version out now. http://www.murtonpikesystems.co.uk
Old 22nd May 2010, 10:07 PM   #6
Here is Dr. Bora's reply:
"I don't think they are very good for amps. Voltages and currents ... OK, but capacitances are to big - likely problems with drive and stability! Sorry, I am too busy for detailed answers."
Thanks.
Max.
Sugestions needed on power amp schematics to fit these MOSFETs.Hide this!Advertise here!
8" Subwoofer cabinet schematics needed. hernanstafe Subwoofers 12 6th February 2007 04:09 AM
Sherwood car amp schematics needed. RetroAudio Swap Meet 0 17th July 2006 01:11 AM
schematics for power mosfets? rx7speed Solid State 3 29th November 2004 09:45 PM
Need help finding push button power switch to fit my amp Ken C Solid State 4 13th July 2004 12:42 AM
Copyright ©1999-2017 diyAudio
