Old 17th May 2010, 11:39 PM   #1
groovebot's Avatar
Question repairing Event 20/20bas active speakers
I'm gonna attempt repair on my Event 20/20bas active speaker.
Intermittently, the sound gets really quiet. flip the power OFF and the sound is at full volume before it slowly fades out again. So i guess it has something to do with the power supply section.
when the power switch is on, it allows some kind of backflow, but when it is off, all the charge in the main capacitors is discharged through the amp circuitry? so I'm just trying to figure out which component has failed and is allowing the current leakage.
Schematic attached.
Old 18th May 2010, 11:52 AM   #2
MikeHunt79's Avatar
Hi, I don't have experience with that specific model but I did have a pair of Event TR8 speakers and one of them completely stopped working. It turned out the LM3886 was bad, most likely because of the almost non-existent heatsink! Some severe cost-cutting with this model...
I've not replaced all of the Event circuitry with a Class-D amp now, and the speakers now sound a lot nicer with better dynamics.
So, I would check the voltages going into the amp, and see if they are dropping when the volume is turned up, I would be more likely to suspect the amp than the power supply myself.
Anyone have a service manual or schematic for an Event TR8 active speaker? MikeHunt79 Chip Amps 20 2nd December 2011 01:44 PM
20 channels system (with active cross over) knc Digital Line Level 12 7th October 2008 07:07 PM
Event 20/20bas - replace old LF Drivers? casimer Multi-Way 1 5th February 2008 11:56 AM
repairing Yamaha NS-690 II speakers TimboW Multi-Way 14 1st November 2006 02:16 AM
Repairing and modifying speakers Hayden Multi-Way 9 3rd July 2005 02:12 PM
Page generated in 0.15387 seconds (30.75% PHP - 69.25% MySQL) with 11 queries
