Low and distorted output after amplifier heats up
Old 16th May 2010, 09:17 AM   #1
wabun is offline wabun  United States
Default Low and distorted output after amplifier heats up
my Krell KSA150 sings well when switch on, but after play for 3 songs, the left channel output become lower and lower with some significant distortion but when I switch it off, let it cool down, and turn on again, it sings well for 3 songs then left channel output become lower again, does anyone know why this can happen ? Sorry for my poor English, I am new to this Blog..
Old 16th May 2010, 05:31 PM   #2
Jan Dupont is offline Jan Dupont  Denmark
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
This can be caused by a bad soldering. When the component heats up the connection gets bad......
Do you have any skills for do such fault finding ?
Free Schematic and Service Manual downloads www.audio-circuit.dk, Spare time company (just for fun): www.dupont-audio.com
Old 16th May 2010, 08:47 PM   #3
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Do an inspection of the soldered joints and look for a bad one.
Other than that could be a bad wire connection.
PCBCAD51 pcb design software. 2018 version out now. https://www.ebay.co.uk/sch/i.html?_f...nload&_sacat=0
Old 16th May 2010, 08:59 PM   #4
smartx21 is offline smartx21  Brazil
Send a message via MSN to smartx21 Low and distorted output after amplifier heats up
Consider also searching for schematics and measure voltages along the circuit. An almost dead transistor, a blown resistor...
If cannot have schematics, try to search for lacks within the circuit, comparing to the functional channel. But be careful to manage the probes while power is on.
With power off, you can compare measures from selected parts, starting from power supply (if separate), and output stages.
Once my home amp had the contacts of electrolytics totally oxidated.
Good luck!
Max.
Old 18th May 2010, 09:11 AM   #5
thanks for the suggestion, I have some repaired simple amps like NAD3020 or Sansui, but not for Krell, 1st time handle complicated amp. I do inspect the solder joint with magnifying glass, could't foud any cold joint. Is there any way to identify weak transistor ?
Could it be the driver that provide thermal feedback faulty ? Krell amp uses very less jumper wires. schematics also cannot be found, headache..
Old 18th May 2010, 10:33 PM   #6
Nico Ras is offline Nico Ras  South Africa
Nico Ras's Avatar
Krell is a relatively simple design and the reason for its good performance on a whole. I would be inclined to think that one channel is thermally running away and that the distortion is caused by break-down.
Have a look at the voltage developed across the output transistor emitter resistor and see if it continues to rise (no music) if it is then there could be a problem with the bias pot wiper or a bad thermal connection with the Vbe multiplier.
Nico
Old 18th May 2010, 10:38 PM   #7
Nico Ras's Avatar
A further problem might occur in that the pot in the offset adjust could be faulty, since Dan Agustino feeds DC into the feedback amp to adjust off-set and also places two small caps across this pot. If one of these caps are leaking then you would also see the output offset change with time and if allowed to rise to the one half cycle of the music clipping due to off-set drift could sound like your problem.
Nico
Low and distorted output after amplifier heats upHide this!Advertise here!
A&R Cambridge A60 Amp left channel very low distorted barhardy Solid State 3 18th May 2010 09:13 AM
MTX 4250D distorted output bil Car Audio 3 5th April 2008 04:30 PM
repair'-Acoustic 450 distorted and low volume. Transistor crossover distortion? Willampsburn Solid State 1 14th March 2008 03:39 PM
1st cap heats up... JojoD818 Tubes / Valves 11 21st September 2006 06:33 PM
Amplifier Output Distorted Rotellian Solid State 12 10th May 2006 02:49 PM
