Old 14th May 2010, 07:40 PM   #1
steevo is offline steevo  United Kingdom
Default Quad 909 buzz problem
Just bought a Quad 909 from ebay 6 months old with 6 months waranty left on it. Excellent condition but one problem, a small amout of buzz coming from both speakers when plugged into my preamp. When not connected one channel does not have any buzz at all and is perfect the other has a very faint amout. when I connect each channel to the preamp individually, the bad channel with the very faint buzz increase in magnitude, the other channel has absolutley no buzz at all when connected on its own to the preamp. Connecting both channels causes a small amount of buzz to appear at their outputs. This is obviously destryoing the distortion and signal to noise ratio performance of amplifier and is annyoying me. I would expect more from quad. I Suspect there is an internal gronuding problem within the power amp or grounding system is wrong. Incidental there is no earth connection at the mian suupply. The mains supply is a standard kettle plug but the earth pin has been removed from the socket on the amp.
Anyone any ideas how to fix the buzz problem.
Cheers
Old 4th July 2011, 05:20 PM   #2
Default 909 buzzing
Hi, this seems to be a bit of a common problem. Fidele Audio have a good fix but at the moment this is only avaialble with an upgrade. Quad have a fix but it seems there might be some sound quality degredation with there fix.
Old 5th July 2011, 12:15 AM   #3
Tajzmaj is offline Tajzmaj  Slovenia
It looks like there is something wrong with your grounding system....?
606,707,909 and smaller 306,520...amplifiers has no center tap at the psu transformer but has floating ground which is fixed by help of 2 small transistors.....and because you remove ground from mains plug all other components connected to the 909 grounds them to this floating ground via 10E resistors on each board. My advice is to remove all the inputs and than observe this buzz. If there is nothing than amp is ok. If there is still some buzz than amp is defective....so send it back ......
Best, Taj
Old 26th October 2011, 04:44 PM   #4
after two unsuccessful attempts by Quad to cure my buzz problem and somehow them muting the musically of the amp to boot in their attempts i gave up bit the bullit surrendered nearly four years Quad extended warranty and sent my 909 to Fidele Audio. they fixed it, carried out upgrades for me and removed the Quadlink. Result .........absolutely superb. regards gw
Better Opamp in QUAD 606/909 Power amp arupg Solid State 14 19th September 2011 05:59 PM
QUAD 909 Mono, voltage converting. KOL69 Solid State 1 15th March 2009 03:54 PM
quad 909 dj_maxxro Solid State 0 4th October 2005 04:11 AM
McCormack DNA125 & Quad 909 Al Raj Solid State 3 8th August 2005 09:51 AM
New bridged quad 909 power amp affordablehifi Solid State 4 21st February 2005 03:23 PM
Page generated in 0.08765 seconds (61.22% PHP - 38.78% MySQL) with 10 queries
