I want to examine the possibility of creating a variable resistor to retain the parameters of a normal, good quality fixed value resistor. The main quality is little or no change with temperature, current, voltage and frequency.
A potentiometer, I found, is too noisy and unstable, does not like DC through it and so on. A simple transistor can act as a variable resistor between collector and emitter, unfortunately I do not know how to control it so its "resistance" stays the same regardless of Vce and Ic. Any ideas? I skipped-read the thread about the LED controlled resistor thingy, and maybe this is a solution? |
#2 |
Did it Himself
Check out stepped attenuators.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
Ah I see, a huge switch with dozens of resistors. Just like what I have on my ageing bench power supply.
#4 |
Forgot to say that is certainly a possibility and in that case I'd use just 4 settings, I would not need more. A rotary switch with 4 positions, and 4 resistors. Maybe 6 positions and 6 resistors.
But if I wanted something that will do the job on the PCB, not at the front panel so the signal does not have to travel over extra wires. |
#5 |
Did it Himself
Digital pot chip then.
#6 |
I think the potentiometer problems you experience are from cheap pots. Try a wire wound in the 500 ohm size.
Like this except PCB? 43C1500 Honeywell Potentiometers or this? Digi-Key - SP140-1.0K-ND (Manufacturer - 140-0-0-102)
What the other guy said----Standing on the shoulders of giants. New avatar- no more little array
#7 |
These pots are very expensive, I can buy two Eminence Stonehenge 12" speakers for that price, and the speakers are the most crucial and expensive part.
My solution will be to use 4 or 6 resistors, placed very close to the transistor (1/4 "), so that the voltage across them stays close to the transistor. There will be 4 or 6 short leads/tracks to a rotary switch (1.5" track + 2-3" leads), and those will be connected to earth. The whole switch will be earthed. Hopefully this will limit noise and distortion. |
#8 |
the 12 position rotary switch is quite cheap.
It can be bought in 4 versions: 12w 1p 6w 2p 4w 3p 3w 4p |
#9 |
Yes I will use a rotary switch, I already have a bunch in my toolbox. The comment about "pots are very expensive" refered to the previous post and some very very expensive wire-wound pots
#10 |
What are you trying to do? Is this something that will be adjusted often like a volume control, or an internal function like bias that's just adjusted every now and then?
CH
I used to be an audiophool like you but then I took an arrow to the knee. |
| Volume control : - pot' or pot' variable feedback resistor (gain) ? | ash_dac | Solid State | 5 | 1st August 2006 05:07 AM |
| How do you make an audio potentiometer into a variable resistor? | Darren Nemeth | Parts | 1 | 10th February 2005 07:15 AM |
| screen-plate resistor and grid leak resistor | metebalci | Tubes / Valves | 4 | 26th February 2004 03:18 AM |
| Using a variable resistor in the feedback loop. | darren01 | Chip Amps | 9 | 30th December 2003 10:05 AM |
| Potentiometer VS variable resistor for level adjusting | Bricolo | Everything Else | 5 | 1st March 2003 01:31 AM |
