Old 12th May 2010, 07:25 PM   #1
sakis is offline sakis  Greece
sakis's Avatar
Default The qla amplifier
here is my latest lay out for an amplifier i make that i call the QLA amplifier (name to be explained in the feature )
demo board and testings are allready done but my previous lay out was way too compact ( very very compact ) that actually had no mistake but the temperature collected in such a small area was a mistake
also previous lay out was only made for 21193 4 while this one may also use biger like 1943-5200
so i thought that is better to have 10 transistors in a length of 30 cm than 15 than the previous f@cking compact pcb was ( costly mistakes )
at this point i will only post the lay out ..it is supposed to be a pro amp and happily working for 350 w @ 8R
further testings schematics and more from this after the pcb is done in the factory
kind regards sakis
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 13th May 2010, 07:22 AM   #2
Ian Finch's Avatar
Hi Sakis - neat looking pattern!
Without calculation, just knowing similar power and 4 each MJL 21193/4 or
2SC 5200 etc. you should get a nice long life wth 5 each transistors producing 350 W into 8 Ohm.
All the same, if not bolting transistors staight to the heatsink, a heavy bracket
(say > 8 mm) is good to avoid hotspots.
regards
regards
Old 13th May 2010, 04:55 PM   #3
Bigun is offline Bigun  Canada
Bigun's Avatar
very attractive symmetrical layout !
no rail fuses ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 13th May 2010, 05:17 PM   #4
sakis's Avatar
well ...in all these years i do PA and construct amplifiers if the amplifier failed there was no fuse enough to prevent explosion ...
i also dont really belive in DC protection ... i am more like a crow bar person if the amplifier has DC in the out cause it failed what diference does it make if it blows one tranistor or all ??? not much since your amp doesnt work anyway and the cost of the gig you loose is by far more than the cost of a few tranistor
then again i have pcb that has rail fuses but for this design is not really effective cause if for accident you loose one fuse then you loose the all amp
you actually need to fuse the amp partially at the output stage ,,,, didnt do that ...will see how its going to work
i have released to work my first ldr limmited amplifier and will se also how it goes as we speak there is kids pushing it death ( at least it has crow bar if something goes wrong )
Old 25th May 2010, 07:46 PM   #5
sakis's Avatar
the qla amplifier comes to life ....one step at time this particular version is something kinda small to listen too ... only 52+52 rails only 2pairs of outputs pair board
this is constructed to listen to cause it measures quiet ok but music has to come out of it after all ...
yet again this version ( even the small one ) includes complete Vi limmiter so ....here is some pictures instead of a 1000 words
the complete box is going to be finalized inside a sory excuse for an amplifier that used to be called milbank .... world famous 100 V amplifier company (world famous in uk ) ...i dont realy expect to look nice when finished ... but as i said this just a demo version hell not even the pcb belongs to the amplifier its a mod from another amplifier but thats ok ... new pcb is on the way
VI limmiter is in a piggy board located down under
regards sakis
Old 25th May 2010, 07:47 PM   #6
sakis's Avatar
and here is some more
Old 25th May 2010, 08:28 PM   #7
nigelwright7557's Avatar
The more copper the better, it costs nothing to have more copper, otherwise it just gets etched away.
Ground planes are good too.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 25th May 2010, 08:47 PM   #8
sakis's Avatar
hei nigel ... hm mmmm ok yes i will agree with the copper thingy but as is said this is a demo version
the original pcb that is going to be used is the one seen on the top ...and since i dont use solder mask some of the needed traces will be feed up with extra soldering to achive thickness
as about ground planes its something ive never done and never will ...i just dont like them ...thanks though
Old 25th May 2010, 08:50 PM   #9
A ground plane connected to ground or zero volts will reduce the impedance of the ground line and so help with possible hum problems.
Old 25th May 2010, 09:04 PM   #10
sakis's Avatar
well yes it might but then again you need to think if you need your ground plane to exist there as "a protection method " IE acting as a shield on your pcb... and then be returned to O volt ...so the reducing of impedance doesnt apply ...
if you use the ground plane as a ground supply to where ever is needed you simply destroy with that the start ground concept ...
so what exactly is the beneffit of a ground plane ???? i think in AF amplifiers is not usefull ...it could be in digital or RF devices ...
only option one could be of some use ... but inductunce and capacitance might created from a bad made GP could make things worst
just a few thoughts
Wanted: DIY amplifier builder with experience. I need a 0.7 ohm stable amplifier Audiophilenoob Swap Meet 34 16th May 2005 11:58 PM
Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. novtango Pass Labs 2 21st October 2002 01:50 AM
Page generated in 0.17760 seconds (67.53% PHP - 32.47% MySQL) with 11 queries
