Differential Pairs
In the recent past i have used MAT02/03 (Analog Devices) diffential pairs for the input stage. They exibit good features except for the Vce. (40V) These transistors are closely matched and have a good long term stability. I found out that these pairs sound excellent in comparison with other pairs i have used.
I have also seen Zetex components in other commercially audio equipment for instance the Quad amplifier. In most cases the sound of this equipment is pretty nice.
Piersma
FT ?
Per,
Of course you can cascode the diff pair for higher voltages, you are right about that.
I am a little confused about the "low" transision frequency, the FT of the MAT types is minimal 190 Mhz. The output capacity for the MAT02 is 23pF. FT for the ZTX1056A is 120 Mhz.
Piersma
