Integrated audio amps without feedback
Old 11th May 2010, 02:25 PM   #1
akis is offline akis  United Kingdom
Default Integrated audio amps without feedback
Is there an op-amp on low frequencies (audio) that only uses pure class A everywhere and does not use negative feedback across multiple internal stages or feedback based on capacitance (eg from collector to base) ? But which somehow allows the gain to be set externally ?
Old 11th May 2010, 02:37 PM   #2
circuitscc is offline circuitscc  United States
circuitscc's Avatar
Most op-amps use class B at the output. Most op-amps allow the gain to set externally.
Hope this helps.
Integrated audio amps without feedbackHide this!Advertise here!
Looking for feedback on Bottlehead amps agweeks Tubes / Valves 24 4th August 2008 07:01 PM
Seperating Preamp from Amp in Integrated Amps camusmuse Tubes / Valves 5 17th May 2008 12:03 AM
2 x Complete Integrated Amps (LM3875) - UK Vikash Swap Meet 5 24th October 2006 01:46 PM
Sony Integrated Amps leka Solid State 2 15th February 2006 02:34 PM
pre+power amps vs integrated amps pkgum Solid State 4 22nd November 2001 01:46 PM
