Old 10th May 2010, 05:51 PM   #1
Thumbs down Power Amplifier blew and took a speaker with it
DIY disaster. I recently made a pair of 12inch speaker cabs with a horn. Got a new amp today to test it on. Disaster.
Today I got my new Skytec Pro 600 amplifier. I know this puts out about 300W each channel and my speakers are 200W max, but I didn't actually drive the amp, I kept it under 2 on the volume dial, so low that not even the db meter was lighting up. However, when I was testing the amp with my iPod, suddenly, the right channel went silent with all db LEDs lit up so I powered the amp down, heard a pop from the right speaker, and that was it. The right channel never worked again. I replaced the cable, and tried a different working speaker on that channel but it just won't work. So I went back to the original speaker and opened it. It smelled a lot like magic smoke. I took the woofer out. It has blown somehow from under 20watts... The left speaker and channel works fine. The right channel is gone completely and so is my woofer. I'm gonna get replacements hopefully, but what could have caused this just so this doesn't happen again. For the record, the horns and crossovers in the speaker which blew still work, its just the woofer.
Old 10th May 2010, 06:37 PM   #2
Steve Dunlap's Avatar
Your amp failed and put out DC. The second speaker you tried is probably blown now also. The horn survived because of the cap in series with it. You may also have burned some of the coils in the crossovers.
Old 10th May 2010, 06:37 PM   #3
LAJ is offline LAJ  United States
Your amp suddenly developed a short and put out DC. Thats why all the LEDs lit up. The DC (probably full rail either plus or minus) burned out the voice coil in the speaker. It was not the audio power (AC voltage) that took out the speaker. An amplifier working properly does not put out DC. Do not reconnect any load until you resolve the DC on the output problem. Typical DC output on any amp is usually like .05 volts. Yours is much more than that!
Old 10th May 2010, 06:39 PM   #4
I´d say large amounts of DC offset, but there are usually protection circuits that would turn off the amp, or disconnect the driver using an output relay. Also, the amp could be oscillating badly at HF frequencies, but this is more likely to fry the tweeter or crossover components. The woofer is likely to be the last thing to blow from HF. So in a way it doesn´t make much sense. My bet´s on DC offset.
Old 10th May 2010, 06:42 PM   #5
Mooly's Avatar
Was this a brand new amp ? I wonder if there is anything load wise with your speakers that upset it (causing instability), although a commercial amp should be absolutely bullet proof and include DC offset protection. Tough luck
A simulation free zone. Design it, build it, test it.
Old 10th May 2010, 06:43 PM   #6
Plammox is offline Plammox  Denmark
Did you use DC-blocking caps between the iPod and the amp? Hint: measure the DC-level of the iPod output. If the amp is also directly coupled, then your speaker unit is toast. I suppose the crossover did what it was supposed to, and let the DC bypass the horn.
Old 10th May 2010, 06:50 PM   #7
Developed a fault? In a matter of minutes? And it blew one of my precious speakers? This is outrageous, good thing the woofer was a cheap crappy 15quid woofer. I'm pretty sure the crossover and horn is fine because it works fine on a hi-fi amp. The second one is fine, I think the right channel is disconnected, its not doing anything now no lights, fuse has probably gone. Is it safe to carry on using the left channel or should I save my second speaker?
Old 10th May 2010, 06:51 PM   #8
Yes it was a brand new commercial amp
My speakers were 8Ohm, which is in the clear, the min is 4Ohm
Nope, I didn't know a such thing as DC blocking caps existed but I'm pretty sure the iPod is fine.
Old 10th May 2010, 07:12 PM   #9
jaycee is offline jaycee  United Kingdom
Probably poor manufacturing. Don't use the other channel - return it for a refund.
Old 10th May 2010, 07:15 PM   #10
Thanks for the info... I can't get a refund, it'll have to be a replacement, looks like I'll be staying with my old 15W Sansui AU2200 for now :/
Could I have caused this by connecting the speakers with musical instrument/microphone cable rather than using professional speaker cable? I think it might have been my fault cos in the manual, I'm meant to use proper speaker cables
hafler dh200 blew speaker? hostarn Solid State 18 26th May 2009 01:01 AM
PPI amp (power precision) blew out profuse007 Car Audio 125 7th January 2008 09:30 PM
Page generated in 0.19265 seconds (45.13% PHP - 54.87% MySQL) with 11 queries
