I decided to build an amplifier with parts ready available, that is, reused from computer monitors, PSU, UPS, and some others from my parts bin. The results will be shown here. But the question is: how nice will be the sound quality? Will it last for a long time? Which are the most critical ones that should not be reused? Feel free to post your comments, they are all welcome!
#2 |
Semiconductors, resistors, and capacitors are so inexpensive it's foolish to recycle.
Transformers, heatsinks, and chassis metal-work recycle quite nicely.
Candidates for the Darwin Award should not read this author. |
#3 |
did the same expiramnet with my P3A none of the parts i used was used but i used the lower quality available cheap carbon resistors all transistors chinese not matched fake 1943-5200 and ceramics everywhere
the amplifier is working still after produced two years ago works daily 8-10 hours in a lofi application but perfomance is terrible compaired to the standard "high quality " P3a regards sakis
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
#4 |
It depends on how clever you are and what equipment you have available. No doubt a wonderful amplifier could be build, but you'd need to characterize devices with a curve tracer, find breakdown voltages and such, for all the "house number" parts used in commercial equipment. Some of the capacitors used in switching supplies are probably good, but I wouldn't use any of the resistors found in inexpensive consumer equipment for audio. It's way cheaper and easier to buy the right parts unless you like scavenger hunts!
Conrad
I used to be an audiophool like you but then I took an arrow to the knee. |
#5 |
#6 |
I cant open your pictures
#7 |
#8 |
Maybe pictures were too big. These are small versions.
Regards, Max. |
#9 |
Hm,
well, that transistor 2SC5200 on the left isn't genuine Toshiba's. You can still use it but don't expect high performance. |
#10 |
| How much do you normally spend on parts to build a good crossover | pjpoes | Multi-Way | 12 | 2nd January 2007 04:41 PM |
| Gates CB-77 Good, Great, Junk ? | fortytwo | Analogue Source | 10 | 7th September 2006 12:06 AM |
| Got parts? No what do I build | PeterK | Subwoofers | 9 | 10th July 2005 09:22 PM |
| what amp to build with these parts ? | Groundloops | Solid State | 1 | 28th May 2004 03:24 PM |
| A good reason to buy good parts | jteef | Parts | 3 | 7th February 2003 09:33 PM |
| Page generated in 0.18780 seconds (51.37% PHP - 48.63% MySQL) with 11 queries |
