Thiele-Small reloaded with LTspiceIV
Old 7th May 2010, 08:20 AM   #1
steph_tsf is offline steph_tsf  Belgium
steph_tsf's Avatar
Default Thiele-Small reloaded with LTspiceIV
Here is a LTspiceIV toolkit aiming at simulating a loudspeaker driver in a closed box.
See attached files.
Steph
File Type: jpg Thiele-Small reloaded - closed box.jpg (129.9 KB, 333 views)
File Type: jpg Thiele-Small reloaded - closed box (Bode plot).jpg (97.6 KB, 306 views)
File Type: zip Thiele-Small reloaded with LTspiceIV.zip (162.3 KB, 47 views)
Old 7th May 2010, 07:09 PM   #2
steph_tsf's Avatar
Here are some MONACOR loudspeaker drivers, simulated in free air.
See attached .zip file.
You need the toolkit in the above test for running the simulations.
File Type: jpg Monacor SPH-210 - free air (Impedance & Bode plot).jpg (91.1 KB, 265 views)
Old 7th May 2010, 08:12 PM   #3
infinia is offline infinia  United States
infinia's Avatar
Hi Steph
thanks for posting your model.
I have run some simulations for a 10 woofer looks good so far.
what are some formulas for
1.) C_compl values relating closed box volume in liters
2) " " R losses relating to air leaks > any useful empirical values
assume Lmass is moving mass of driver
4) acoustical stuffing affects all mech terms RLC, but mainly C? changes by some empirical percentages?
Finally why choose a power amp with gain of 1+(33/1.5) ? Does this normalize the acoustical output somehow?
Note > I suppose I could sort all this out using Unibox for awhile.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 8th May 2010, 08:38 AM   #4
steph_tsf's Avatar
Originally Posted by infinia View Post
What are some formulas for
1) C_compl values relating closed box volume in liters
3) acoustical stuffing affects all mech terms RLC, but mainly C? changes by some empirical percentages
4)Why choose a power amp with gain of 1+(33/1.5) ? Does this normalize the acoustical output somehow?
Hello, I'm glad you asked this.
1) There are so many people wanting to think in terms of "litres" when dealing with suspension compliance. My opinion is that one should call a cat a cat. The idea of suspension compliance being expressed in "litres" is a nasty complication. It makes everything fuzzy in my poor, limited mind. Using "litres", I need to remember that this kind of quantification also involves the speaker surface ! No no, here we shall never again use "litres" when dealing with the suspension compliance. Whe shall call a cat a cat. Compliance is the mechanical membrane displacement expressed in meters when your finger (or anything else) applies a force of 1 Newton (= 102 gram) on the membrane. This is so easy to remember, easy to figure !
2) So you seem to say that R_losses is quite an empirical value, quite difficut to objectivate ? Must say I had the same feeling. You are introducing the concept of air leaks. What's this ?
3) Point 3 is unclear for me. Can you detail it ?
4) Excellent question ! The power amplifier gain is the gain of the Kuroda 1982 amp. From there comes the feedback network 33k / 1k5. A few days later, I realized that when specifying an .AC simulation using 1 Volt at the input, that the voltage applied on the speaker model would be more than 30 Volt, much more than the standard "1 Watt" test. I thus lowered the .AC simulation voltage to 100 mV. A few days later, after having defined the internals of the "*s" (differentiator) LTspiceIV component, I needed to define the internals of the "Piston Diameter" LTspiceIV component. Over there I took the decision to tweak the scale factor in such a way that using the .AC 100mV at the input, we get a SPL value equal to the "SPL per watt at 1 meter distance" you can read in any datasheet. This way, looking at the LTspiceIV Bode plot, you get matched with the usual datsheets. This being said, I think I need to slightly reverse engineer this now, for applying a more scientifically precise .AC voltage on the speaker, and accordingly trimming the .AC voltage source, and the scale factor in the "Piston Diameter" block.
Actually, what is the voltage amplitude to be applied on the speaker if one wants to mimic the "1 watt at 1 meter test" leading to the SPL sensitivity figure that gets documented on any speaker datasheet ?
P.S.
I'm here anticipating the remark you will do about putting the driver in a closed box enclosure, effectively decreasing the overall compliance. In this thread I will make a dedicated post explaining in detail the "PV = constant" equation, and the effect of this law when putting a driver in a closed box. It will then become clear why "box volume" may get associated to "compliance", hence "compliance" being sometimes quoted as "equivalent volume" for a particular driver. It will become clear why the closed box is showing as a C_Box capacitor fitted in series with the driver C_Compl. Actually, C_Box needs to be an "intelligent" capacitor, with the capacitor value being computed using a) the box volume and b) the speaker diameter.
Steph
Old 8th May 2010, 09:12 AM   #5
steph_tsf's Avatar
Once the C_Box automatic size calculation gets done, there will be another LTspiceIV .asc template, called "closed box", showing C_Box in series with C_Compl.
I intend using a dedicated symbol for C_Box, for not confusing it with the suspension compliance, and also for allowing the user to enter the two parameters (closed box volume in cubic litres, driver membrane diameter in meters).
I'll chose cubic liters for the volume, for staying in the normalized MKS physical system.
Later on, we'll experiment other enclosures like 4th order bass reflex. While doing this, I intend having the same "bare hands" approach when dealing with the vents.
In a bass-reflex enclosure, a vent is a piston (vent diameter) having a mass (air mass) that gets mobilized by the force existing between the enclosure inside, and the enclosure outside.
Those 32 words, properly understood, should enable us to determine how and where connect the vent in the LTspiceIV equivalent schematic, and how and where collect the associated acoustic emission, with the right polarity.
Old 8th May 2010, 03:23 PM   #6
infinia's Avatar
Hi Steph
Can you suggest to the Mods that this thread s/b moved to 'Multi' forum. It should generate much more input and excitement from members there, even though not too many use spice.
Firstly I use LTspice to model passive xovers. In the past I ignored the Low Frequency (LF) resonance assuming the filters I modeled where at least a couple of octaves higher. HF effects were simply to use Re and Le as a 1st order approx. Taking the pseudo acoustic output across Re. My crude modeling also assumes the HF output of interest is mainly off axis, ie no acoustical cone effects. This was helpful only using wide band drivers well in their pass band.
Now with your model I would like to investigate the LF effects accurately. From your responses above I think you are still early on your work.
I think we should use a simple voltage source with a constant amplitude of 2.83 V RMS and not watts/m and setting the source impedance equal to the amplifier damping factor plus cable/connector losses. The output sensitivity of your model should match other well known LF T/S modeling programs like "Unibox". Also consider the loss effects of passive filters, or zobels, etc inserted on the drivers terminals. RE> losses/ air leaks and stuffing> If you play around with Unibox and re-read R Smalls paper on closed box modeling all your other questions will be answered.
Old 8th May 2010, 04:25 PM   #7
infinia's Avatar
Air Leaks intentional or not, are important to model.
Intentional air leaks are used quite often for high Qts boxes as sort of dynamic reduction in Q. see aperiodic alignments ala restrictive flow vents "Vario vents".
Others maybe less so intentional air leaks are built-in some high power sub drivers that use porous dust caps for VC cooling. Other drivers may use pole pieces instead of dust caps and can be open here as well.
Other air leaks are caused by cabinets not completely sealed, usually much lower in comparison to the first two examples.
Old 8th May 2010, 06:24 PM   #8
steph_tsf's Avatar
Now with your model I would like to investigate the LF effects accurately. From your responses above I think you are still early on your work. I think we should use a simple voltage source with a constant amplitude of 2.83 V RMS and not watts/m and setting the source impedance equal to the amplifier damping factor plus cable/connector losses. The output sensitivity of your model should match other well known LF T/S modeling programs like "Unibox".
I have updated the toolkit. Please replace the old files with the newly supplied here, attached. Now the toolkit is using the "1 Watt on 8 Ohm" standard using a 2.82 V RMS .AC stimulus. The "Piston" block has been updated accordingly. Please have a look to the "Monacor SP-100-8 variations on a theme" file. There you see how powerful and easy LTspiceIV is. If you want to apply motional feedback using an acceleration sensor, there is already a piezo sensor in the toolkit, as symbol and schematic.
File Type: jpg Monacor Monacor SP-100-8 variation on a theme.jpg (129.1 KB, 222 views)
File Type: zip Thiele-Small reloaded with LTspiceIV.zip (25.7 KB, 24 views)
File Type: zip Monacor SP-100-8 variations on a theme.zip (10.6 KB, 19 views)
Old 8th May 2010, 06:39 PM   #9
steph_tsf's Avatar
I went to Elak (an electronic shop in Brussels) grabbing some info about loudspeaker drivers one may eventually purchase at decent prices here in Europe. They gave me the 2009 MONACOR catalog, no less than 710 pages. I did an arbitrary selection of drivers :
Celestion Truvox 1225 ... 500 Watt thay say, but excursion is only +/- 2.4 mm. A joke ? Not suited to deep bass where excursion matters ?
Monacor SPH-100/8 ..... inexpensive, wideband, +/- 3.5 mm excursion
Monacor SPH-100C ...... looks hi-tech but beware the nasty resonance at 9.0 kHz
Monacor SPH-135C ...... looks hi-tech but beware the nasty resonance at 6.5 kHz
Monacor SPH-165 ......... inexpensive, wideband, +/- 3.5 mm excursion
Monacor SPH-165CP ..... looks high-tech but beware the nasty resonance at 7.0 kHz
Monacor SPH-170 ........ inexpensive, wideband, +/- 3.0 mm excursion
Monacor SPH-170C ...... looks hi-tech, wideband, manageable controlled resonance at 4.5 kHz, +/- 4.0 mm excursion
Monacor SPH-176 ........ wideband, +/- 5.5 mm excursion
Monacor SPH-210 ........ nice traditional driver, no pronouced high frequency resonance, +/- 3.5 mm excursion
Monacor SPH-225C ...... looks high-tech, wideband, manageable controlled resonance at 3.0 kHz, +/- 6.0 mm excursion !
Monacor SPH-255 ....... traditional driver, not to be used above 2 kHz, +/- 4.5 mm excursion
Monacor SPH-275C ...... looks high-tech, wideband, small manageable controlled resonances at 3 kHz, +/- 6.0 mm excursion !
Monacor SPH-315 ....... traditional driver, not to be used above 2 kHz, +/- 4.5 mm excursion
The MONACOR catalog provides the impedance curve along with most electrical, mechanical and electromechanical data in tabular form. Looks nice at first glance.
I was thus able to enter the necessary data in the LTspiceIV Thiel-Small toolbox.
I must however report a few facts.
1.
The equivalent loss resistor is never quoted by Monacor. However, it is easy to retrieve it when looking at the impedance plot. When all the other parameters have been duly entered in the LTspiveIV toolbox, an impedance plot (voltage / current) tells you if you need to increase or reduce the equivalent loss resistor. The maximum impedance at resonance is governed by the value of the equivalent loss resistor. I have thus set the equivalent loss resistor for obtaining the same max value, under LTspiceIV toolbox, than showed by the impedance plot published by Monacor.
2.
The coil inductance specified by Monacor seems to be systematically exagerated. The coil inductance specified in the Monacor tables doesn't fit with the value showing on the Monacor impedance plot at 20 kHz. So, as expected, if one enters the tabular value of the coil inductance in the LTspiceIV toolbox, the impedance displayed by LTspiceIV at 20 kHz is ways above the impedance showed in the Monacor impedance plot at 20 kHz. In order to get a impedance at 20 Khz equal to the value displayed by the Monacor impedance plot, I have adjusted (lowered) the value of the coil inductance in the LTspiceIV models. This needs to be investigated. The value of the coil inductance is of importance in the Servo-Sound applications (back EMF voltage extraction).
3.
After having entered all the data in all the models, we can't say that there is always a perfect match between the free-air resonance frequency, comparing the Monacor impedance plot with the Monacor tabular data, and with the LTspicsIV impedance plot.
Let us take an example : the SPH-225C (quite my favourite driver, from the supplied data) has the resonance peak at 46 Hz on the graph that is supplied by Monacor. But when you read the Monacor tabular data, they say that the resonance is at 39 Hz. And when you ask LTspiceIV, the impedance peak occurs at 39.9 Hz.
We have the same case with the SPH-210 (a traditional regular driver). It has the resonance peak at 34 Hz on the graph that is supplied by Monacor. But when you read the Monacor tabular data, they say that the resonance is at 28 Hz. And when you ask LTspiceIV, the impedance peak occurs at 27.8 Hz.
So what ?
Would be nice if somebody takes some time explaining me why the inductance values (tabular data) specified by Monacor are always incompatible with the Monacor impedance plots, and why the Monacor resonance frequency value (tabular data) are incompatible with the Monacor impedance plots.
This being said, I have a doubt about the Design Data Base for Unibox that's available here : UniBox - Unified Box Model for Loudspeaker Design
Old 8th May 2010, 06:52 PM   #10
event horizon is offline event horizon  England
event horizon's Avatar
Hi steph, yes they are rather nice aren't they I have four of them here ready to go into a BMTMB arrangement along with Yamahas beryllium midranges & tweeter unit. Deep bass will be supplied by 2 x 15" per channel.
Not sure if you happen to have one or more there but if you need some measurements of the drivers let me know & i'll see what i can do
Interesting thread by the way, i'm not sure i fully understand it but i have dropped in previously. Had to comment when you brought up the SPH-225C though...
Bests, Mark.
"Never let your morals prevent you from doing what is right!" Salvor Hardin
Thiele-Small reloaded with LTspiceIVHide this!Advertise here!
Thiele-Small Explained? marob Multi-Way 14 24th June 2013 05:14 PM
Thiele - Small parameters tomtt Multi-Way 0 25th March 2009 02:48 AM
Thiele-Small parameters Hoffmeyer Multi-Way 6 15th March 2006 01:12 AM
DIY Thiele/Small measurements ?? youyoung21147 Full Range 19 5th October 2005 05:10 PM
Thiele-Small importance bigswede Multi-Way 4 12th September 2002 07:21 PM
Copyright ©1999-2017 diyAudio
