Old 6th May 2010, 02:09 PM   #1
Default OPA627 at +/-5V in Sony CDP-508ESD
I've been modding my 508ESD with Burr Brown PCM58P DACS and have been following the discussions on this board about OPA627, which I selected for the op amps.
The concern I have is that the OP AMP supply on the 508 is +/-5V, which is less than most other applications I've read.
I installed the OPA627s on Brown Dogg adapters, added an audio grade 100 uF Nichicon capacitors to each supply input on each opamp (4 in total), and placed a 560 Ohm resistor from output to -V supply to obtain a 9-10 mA bias into class A, which obviously does not cause a heat problem at 5v. The sound seems noticeably improved since before adding the caps and resistor.
Does anyone have any comments / recommendations when operating this opamp at low voltage?
Old 6th May 2010, 04:42 PM   #2
Notes on Audio Op-Amps
That link shows the min voltage for a bunch of opamps. OPA627 came in at:
Vmin, 0.5V into 33 Ω: 6.8V
Vmin, 2.0V into 330 Ω: 9.8V
Just a wild idea I had would be you could try building a bigger battery compartment and tie the extra cells directly to the opamps because extra voltage may/may not affect how the transport and dac run. Your other option is to just use other opamps.
I've tested quite a lot of the opamps from that list in my little dot I+. I have lme49860, lt1364, ad8599, ad823, ad8610 ,opa227, opa2132, opa123, opa627. I found opa627 to have superior detail and balance. Depending on the role of the opamp I/V or gain stage they may work better or worse. I have lme49860 in my I/V and it's good.
His comparison shows AD823, Ad8065, and AD8397 to be the best for low voltage so you might just try those 3 and see which works best.
Old 6th May 2010, 05:37 PM   #3
Thanks.
He defines the voltage as rail to rail, though. So when he says 9.8V is needed, my rail to rail voltage is +5.1V - (-5.1V) = 10.2V, which is acceptable.
I haven't noticed any problems - the sound seems very strong through headphones.
But, given the fact that many say this opamp performs better at higher volatges, I'm wondering if anyone would suggest further tweaks.
Old 7th May 2010, 06:19 PM   #4
Mooly's Avatar
What those figures don't show in natek83's link is how the distortion rises as load impedance falls.
No opamp will drive loads of such a low value as 33 ohm correctly, the distortion will increase dramatically, as well as a virtually non existant output voltage swing... even if it seems to sound OK at low levels.
600 ohm is a recognised "minimum" for many devices, and for some older chips such as TLOxx's etc it's far higher than that.
Rather than use a resistor (560 ohms... that's bit on the low side), an active constant surrent source/sink is better, perhaps using 1 or 2 jfets. The current flowing in a resistor is anything but constant as the output signal varies. As the signal approaches the negative rail the current falls away, at the other extreme as it approaches the positive rail the current flowing in the resistor approaches 18ma approx.
I would have thought 3 or 4 ma at most to be sufficient (if you feel the need to bias them in this way in the first place).
A simulation free zone. Design it, build it, test it.
Old 8th May 2010, 01:24 AM   #5
EUVL is offline EUVL  Europe
I tried the OPA627 in my Meridian 508 to replace the original NE5532s, and they worked at +/-5V. There was improvement, but the OPA627 really wants the full +/- 15V to give best performance. I am now using LT6230, which is happy at +/-5V. In fact there is a whole lot of low-voltage of opamps to choose from these days, like the ADA4841, TS971, etc.
You will need to make a small adaptor board yourself.
Patrick
Sony CDP-D500 & CDP-2700 audiobot Digital Source 2 20th December 2009 11:44 AM
Sony cdp-715 gacpar Digital Source 0 19th October 2009 10:21 PM
Sony CDP-337ESD v Sony CDP-X33ES which is best? eldarvanyar Digital Source 0 10th January 2008 11:04 AM
WTB: SONY CDP-X3000ES or CDP-X5000ES cartman Swap Meet 0 18th April 2007 06:16 PM
Sony CDP 101 Zero One Digital Source 2 28th April 2006 09:06 AM
Page generated in 0.55539 seconds (14.40% PHP - 85.60% MySQL) with 11 queries
