www.batchpcb.com
This looks like a very cool way to manufacture and distribute short run amplifier PCBs once a layout is done. It looks like it would make group buys a lot easier to manage. I have no involvement with that business. I just saw a short article on the IEEE website that mentioned it. ..Todd Last edited by taj; 5th May 2010 at 02:26 PM. |
#2 |
Cost is about 1/2 of what I currently use. Always looking for a beter answer.
#3 |
looks interesting ...\
thanks for the pointer. mlloyd1 |
#4 |
I've used these guys for quite a while. Very good service. The web interface and DRC are better than everything else I've used, board quality is very good, and of course so is the price.
Beware of the turn time though, it will take minimum 4 weeks to receive your boards, in my experience it's usually closer to 6. Also interesting is that you can 'release' your project for sale on their site marketplace. Upload the gerbers and other folks can then order their own boards directly.
http://audio.gotroot.ca/ |
#5 |
I have found Chinese manufacturers to be very good.
I get a batch of PCB's from China for the cost of tooling in the UK !
http://www.murtonpikesystems.co.uk PCBCAD50 pcb design software. |
#6 | |
Short time, no speak. I have a PCB will BatchPCB at the moment. Crunching through the numbers, they are only economical for small run and/or small PCBs. i.e 4 x sub 1" squ PCB cost $5 each (includes delivery). A small amp sized PCB costs something like $25 each. If you only get 2 then $50 is still OK. But increase that to 4 boards then its $100 and you can do better. If I made this small PCB available for others to purchase, it would cost $2.50 plus delivery. Products regards
Greg Erskine |
#7 | |
They seem to provide a good service even though it does have to come half way around the world to get to me. Turn around time is usually a month in total.
#8 |
The part that caught my eye was the marketplace. You provide the design, pay for setup, and people buy the PCBs. If it's too expensive to do that way, then their business model is not what I thought it was.
I was thinking something like CafePress.com for PCBs. I guess it's not close enough. I'll keep waiting. ![]() ..Todd |
#9 | |
This issue is with our group buys, when the number of PCBs gets into the hundreds, the cost of a PCB drops to only a couple of dollars per PCB. A lot cheaper than above. Of course the group buys only work because someone is graciously donating their time at nil cost. ![]() BatchPCB forum: http://forum.sparkfun.com/viewforum.php?f=16
Greg Erskine Last edited by Greg Erskine; 6th May 2010 at 03:46 AM. |
#10 |
For somewhat larger quantities, Gold Phoenix is the PCB manufacturing house that BatchPCB uses. $100 USD for 155 sq. in 2-layer, free panelization with much better turn time.
Still can probably do better for large runs though.
| BatchPCB - My first order just came in | TheSeekerr | Construction Tips | 0 | 29th April 2010 12:27 AM |
| Will this keep me cool enough? | littlerick | Chip Amps | 15 | 4th January 2010 08:11 PM |
| Just built a cool database- help me fill it. -- Resource for DIY. | brianpowers27 | Multi-Way | 4 | 13th October 2009 07:55 AM |
| This is cool | tubelab.com | Tubes / Valves | 5 | 29th November 2006 11:29 PM |
| Really cool! | mdlover | The Lounge | 9 | 18th November 2003 05:56 AM |
