I've just constructed this pre-amp for a friend. When I plugged it in, all I got was a constant (earth??) hum from both channels:
http://www.reprise.com/host/circuits/riaa_preamp.asp The only modification to the circuit I made was placing a 1000microF 35V electrolytic between the 12V rail and earth, to smooth the 12V DC from a wall-wart power supply. I made it on perf/vero board and used only one track for all my earth connections, ie. everythging on the circuit diagram showing a "ground" symbol were all connected to the 0 V wire from the DC power pack/wall-wart. Ive checked all the connections etc and am reasonably sure I've got the components connected as they're supposed to be according to the circuit daigram. I'd very much appreciate any help/suggestions for whats going wrong - I'm very much an amateur on electronic matters. Cheers, Joseph |
#2 |
This circuit shure looks like a horror movie - single rail opamps, cap-coupled cart...
good luck peter |
#3 | |
#4 |
Have to admit shurely not a big fan
#5 |
Electrons are yellow and more is better!
BM, one thing is obvious: You can't use those 91 + 100 k at the input without any decoupling unless the power supply is VERY silent (don't think so). Noise (or hum) is fed directly into the amp. Check also if you really have stabilized voltage! It's a must.
My suggestion is to have a voltage divider 2+2 to 10+10k and a cap of 10-100 uF down to signal ground. From the junction a 47 k resistor to the + input of the opamp.
/Per-Anders (my first name) or P-A as my friends call me |
#6 |
I gotta agree with the rest of those who've replied already - this circuit is distinctly lacking in merit. There is a laundry list of faults here; some, but by no means all would be:
The 5532's are so vastly superior to the TL072's in every specification that counts here that it defies reason to not use them both as the input buffer and RIAA compensation amplifier. Using a single supply when it is not necessary - i.e., you have only a 9V battery to work with and no room for rail-splitting techniques - really lacks reason in audio applications. By running this circuit off a dual-polarity supply one could dispense with the input and output blocking capacitors and that questionable biasing network composed of the 91k and 100k resistors (these should be equal, btw...). Also, I don't think the R and C values specified in the TL072's feedback loop will give a proper RIAA compensation curve. Already we have tossed out pretty much every detail of the circuit as it stands, which ought to lead you to wonder whether this circuit should even be bothered with in the first place?!
Before you make that audacious claim, check this site out:QAudio Myths |
#7 |
Thanks for your help everyone.
Haven't had enough time to recheck thoroughly, but I quickly checked the voltages at pins 3, 5 and 7 on the 5532 and they were at about 90% of the supply voltage. I suspect I've made an error translating the circuit from paper onto veroboard. If the biasing network of 100K + 91K resistors are questionable, what values should I substitue?? I'm also wondering if the way I've grounded everything is ok/workable (if not ideal), ie. everything on the circuit diagram showing a "ground" symbol were all connected to the 0 V wire from the DC power pack/wall-wart? I realise the cicuit is going to be LoFi, but I chose it because I want to power it from a 12VDC wall-wart power supply (fiscal prudence decision) - I'm building the pre-amp for a friend so he can plug a turntable into his all flashy disco-light bedraggled Aiwa mini system that doesn't sound too good anyway (understatement). If anyone knows of a suitable (ie. cheap) alternative that I can still power from the 12VDC plug let me know.... Cheers, Joseph http://www.reprise.com/host/circuits/riaa_preamp.asp |
#8 | |
If lo-fi is acceptable, then save the 5532 for something better and just use a single TL074 (the quad version of the '072). Oh, and I still don't think that RIAA curve will come out right. Course, nothin' else is gonna come out of this amp right, so what's a screwed up breakpoint or two in the RIAA curve, eh?
#9 |
A couple more quick questions....
Found the problem and got the preamp working now......except there's still a lot of hum in the background. I'm going to put in a 12V regulator (could this stop a lot of the hum???). Also, the output from this preamp is far too large - I'm thinking the best way to do this would be a dual-pot on the output. What value should I use and would a log or linear pot be best??? BTW - the problem with the preamp was that the shop assistant sold me an NE5532 dual op amp and then gave me an NE5534 single op amp. I didn't check the labelling close enough when I put it into the circuit. Cheers, Joseph |
#10 | |
know it learn, always read the component labelling before you put it on the PCB. And, it is also a good practice to recheck all components again after soldering, but before you power up. |
| Simple phono stage (MC) | Onvinyl | Analog Line Level | 5 | 9th August 2008 09:50 PM |
| The NSSPS (Not So Simple Phono Stage) | dsavitsk | Analogue Source | 10 | 15th November 2005 04:52 AM |
| Rjm simple tube phono pre | ebijma | Tubes / Valves | 2 | 29th September 2005 05:03 AM |
| simple phono preamp circuit needed | needtubes | Tubes / Valves | 4 | 3rd July 2004 08:27 PM |
| Page generated in 0.23318 seconds (46.33% PHP - 53.67% MySQL) with 10 queries |
