I build an amplifier Symmetric....(8 transistors)
why when exchange the type size of my protoboard amp the hi frecuency sound more clear? Exchange the value resistors in the base of output transistors the sound change too ???why |
#2 | |
When you put a resistor in series with the base, then it together the input cap of transistor form a pass-bass filter, so the bandwith is reduced (more high value resistor, more reduced bdw). Francesco. Last edited by mos57; 4th May 2010 at 07:43 AM. |
#3 |
No have input capacitor ..the amp is all dc coupled....the base resistors are 47r..put 4,7r and sound more clear.
Input 2sc1815 (2) 2sa1015(2) Drivers 2sd600-2sb631 output 2sc3856-2sa1492 |
#4 |
As i explain above when you put an higher resistor then the band is reduced (read lower high frequency).
Francesco |
#5 |
#6 |
no have comment about this?
But tre diferent sound is present......Ok |
#7 |
Did it Himself
You have been answered at least twice
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#8 |
More clear may just noise is reduced. Better board means lower bad interference. Lower Rb gives smaller compensated voltages.
| PC sound card sound chips | kaluchka | Chip Amps | 6 | 20th June 2011 03:48 PM |
| The Ultimate Sound Improving for Compact Disc's through Patent-Pend.CD Sound Improver | tiefbassuebertr | Digital Source | 145 | 25th April 2011 07:39 PM |
| Eighteen Sound (18 Sound) NSD 1095N Compression Drivers and XT1086 Horns | opc | Swap Meet | 6 | 1st May 2009 03:48 AM |
| How to isolate diferent devices using 12V DC. | lagoausente | Power Supplies | 30 | 17th December 2006 11:23 AM |
| How to isolate diferent devices using 12V DC. | lagoausente | Analog Line Level | 0 | 2nd November 2006 08:52 PM |
| Page generated in 0.10004 seconds (75.48% PHP - 24.52% MySQL) with 10 queries |
