here is a hardman with some weird behaviour
the unit is in mint condition everything is fine all cps are replaced inside but offset doesnt want to cope in any possible way multiturns are installed ofset can be easilly set to zero but in any temperature variation offset rides to a100 or 200 or 300 millivolt or more hardman did some excersize on thermal junction actually bolting tranistors in some plastic to ensure full contact and thus balance of temperature between the two semis .... though it seems that long term stability was effected since a lot of temperature rised inside the bolt resulting to thermal stress of soldering there is a picture of the schematic and pictures of the thermal junction Q422-426 getting quiet hot and touching the a bit is enough to alter ofset dramatically any ideas ???
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
#2 |
checked all voltages it is with in 10% according to the schematics everywhere
that is strange eee
#3 |
temperature over transistors 426-422 is almost 65 degrees ...that is way too much i think
#4 |
#5 |
yes i did ...also i have checked all voltages according to the schematic and all seems fine ... also replaced a few resistors that looked susspicious but made no diference
#6 |
Harman Kardons are prone to offset drifting because they use low over all global feedback.
You can set the offset at the correct level and then a few minutes later it may have drifted a few tens of millivolts. This is perfectly normal with this type of design. Also they are biased to run fairly warm. regards Trevor |
#7 |
seems silly to me that they used 2xTO-92L devices instead of a TO-126
#8 |
thanks for your input ...yes it could be ok with a few millivolts variations though like 300 millivolt plus or minus is too much
yet again 65 degrees over the 426-422 tranistors is also too much ... there is got to be something else wrong as about the bias ...service manual says 30 millivolt over the emmiter resistors ...that is equal to nothing i presume ....also main heatsink stays relativelly cold only these tranistors are boilig thanks
#9 |
if any body cares to help or see there is a strange protection circuit that i ve never seen before ... and i thought that it might be a good idea to remove it to see if this is effecting the offset stabilty ... as you can see there is two troubles ...one is the ofset stability and the other is the overheating of the transitors
here is the protection
#10 |
i could see perhaps a faulty q418 or a fault in the protection circuit messing with it. might be worth pulling that temporarily?
what was the original fault? |
| HVAC Experts out there? | lgreen | Everything Else | 7 | 2nd August 2009 11:41 PM |
| hardman cardon AVR20II | sakis | Solid State | 0 | 9th January 2009 07:41 AM |
| A question for the experts | Vaughan | Subwoofers | 36 | 20th August 2007 09:40 PM |
| For Sale Harman Kardon T60 Turntable / Harman Kardon Cd491 Cassette Deck | electric blue | Swap Meet | 1 | 25th August 2006 11:36 PM |
| Need help from the experts | bateman | Multi-Way | 1 | 22nd June 2003 02:29 AM |
| Page generated in 0.28876 seconds (31.00% PHP - 69.00% MySQL) with 11 queries |
