Hi all
I'm now designing a class AB mosfet amplifier with IRF240 and IRFP9240. Since now I have not designed any mosfet amplifier and any amplifier with high voltage supply. The supply voltage are probably +-45/50V I'm thinking to use mmbt5401/mmbt5551 (th: 2n5401/2n5501) or fjv992/fjv1845 (th: ksa992, ksc1845) for the current mirror input stage if I'll wish more hfe. For the VAS i'm thinking to use ksa1201/ksc2881. What do you think about those transistors? I haven't seen those in many design. Are a good choice? Any other idea regarding SMD transistor for driving a 100V mosfet design? PS: sorry for my bad english. |
#2 |
I use MPSA42 for LTP and its constant current source.
For the VAS and its current source I use MJE340 and MJE350.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#3 |
I don't know what voltages the smd types are available in, but for a +-50Vdc amp you may have to consider cascoding to get these tiny devices within their thermal and voltage limits.
For both LTP and VAS you need good hFE over the range of working currents, low Cob at 5V and 10Vce, medium to high fT at your working currents.
regards Andrew T. Last edited by AndrewT; 2nd May 2010 at 06:46 PM. |
#4 |
thanks for answares.
Both couple mpsa42/92 and mje340/350 have smd brothers. I prefer avodi cascode input stage for many reason, the first is that increase complexity without a sound improvement. SMD transistors placed correctly offer a better termal uniformity and less noise than a trough hole solution. I will calculate the heating of all transistor during the components choice. |
#5 |
Hey pdp, what did you go for in the end?
The response of the inner ear extends to at least 200khz - Dr W. Tempest |
#6 |
hi pdp11,
my english is also bad, so I hope we can communicate Do you know == Diodes, Inc. == ? Since there are a lot of interesting transistor. |
#7 | |
#8 |
I like SMDs, but I don't like to work with it. So I build my amps with big devices. In one of my next projects I will evaluate an amp with SMDs.
MMDT5401 and MMDT5551 are very interesting, because there are two transistors in one case. Important for mirrors and diffamps. I have very good experience with 2N5551/5401, so I give them a try. |
#9 |
Most of those SMDs come in duel or quad packages which makes for many less 'components' to solder.
All the trouble I've ever been in started out as fun...... |
#10 |
Thank you.
| How to design input stage with specific input impedance/pot value | mahleriana | Tubes / Valves | 0 | 16th November 2009 09:37 PM |
| Monlithic transistor IC for input stage design? | Bitrex | Solid State | 16 | 24th June 2009 01:23 AM |
| Differential transistor input stage | aguantesoda | Solid State | 48 | 11th April 2007 06:36 PM |
| current bias j-fet input 2sk170 ,2sj74 at input stage | YUTK | Solid State | 11 | 2nd June 2005 03:34 AM |
| Page generated in 0.15126 seconds (65.09% PHP - 34.91% MySQL) with 10 queries |
