Rate/comment my power amp
Old 30th April 2010, 05:44 AM   #1
larryB is offline larryB  Canada
Default Rate/comment my power amp
Here is my attempt at making a power amp , I am better at making pcb than making drawings of circuits , I understand good layoud is very important and very short noding and far away noding from important areas .
This is to be used as +-15 v regulated transformer type power supply with outside battery.
Will be using op amp lm7322 for driving mosfets in bias mode , will be using probably the class d lateral mosfets .
Load is yet to be determined , much higher impedance than 8 ohm and not much current .
I await all of your comments with impatience
Regards , LarryB
Old 30th April 2010, 09:09 AM   #2
Nrik is offline Nrik  Denmark
Won't work. The output curve for the lower opamp is not shown in correct phase, and the current in the transformer will outbalance eachother leaving you with zero output, a hot transfromer if the MOSFETs survive it.
You should check out Eva's Zeus amp - looks a bit like this, is simpler, and can be made to work with good support in the forum.
Henrik
Old 30th April 2010, 10:00 AM   #3
ontoaba is offline ontoaba  Indonesia
ontoaba's Avatar
Hi Larry.
You creating another one, but this one better than before, good job. You need to learn about MOSFET driving. Download some mosfet datasheets and read all the Vgs graphs, it will helpful.
Old 30th April 2010, 11:38 AM   #4
Mooly's Avatar
OK, this is never going to work in a million years... but don't let that put you off.
What sort of load are you trying to drive ?
Does it have to use an output transformer ?
Why the discrete phase splitter... it can all be done with those opamps.
Rate/comment my power ampHide this!Advertise here!
Rate and comment my poweramp design larryB Solid State 5 18th April 2010 11:42 AM
Schematic Comment on 'Principles of Power" book ?? calico88 Tubes / Valves 2 4th February 2007 03:18 PM
Estimate power transformer current rate? vax9000 Tubes / Valves 3 6th May 2006 12:49 AM
slew rate and power output. JBL Everything Else 2 16th September 2001 11:51 PM
Copyright ©1999-2017 diyAudio
