Audio Junkie
I am repairing an AB systems 900A amp that uses TIP122/127 Darlingtons as drivers. From what i am reading the TIP127 is a high failure rate part which explains why the three dead boards i have on hand all have then 127 removed...
Can anyone recommend a suitable replacement? Zc |
#2 |
I'd be tempted to try the TIP147, they seem quite robust and should work in the same position - 100volt darlington device like the 127
#3 |
BDX33C/BDX34C - a 100V, 10A darlington that's multiple sourced by ON Semi, ST, Philips and maybe Infineon.
#4 |
Audio Junkie
I have the TIP147's in stock but they are a larger case size. It will take some magic to get them to work but it's worth a shot. I will look into the BDX parts thanks LG
#5 |
May I suggest then TIP107. It is also TO220, also 100v, but rated 8A instead of 5A.
#6 | |
Might the high failure rate be caused by excessive VCE or excessive dissipation over the device? In both cases I think TIP 107 will not help. Regards, |
#7 |
Audio Junkie
I am not exactly sure why they fail. either they fail and take out other parts, or other parts fail and take out the 127's every time. Probably when an output device fails it takes out the 127 i dunno...but the 122 never dies. so i thought i would try an alternate and see what happens.
Zc |
#8 |
Interestingly TIP107 has higher current gain, better DC safe operating area but worse pulsed SOA. So for audio applications it may actually help.
Internal resistors are higher value on TIP107, though.
I use to feel like the small child in The Emperor's New Clothes tale |
#9 |
Can we see the schematics?
| replacement tweeter suggestions for Audax TM025F1? | mondogenerator | Multi-Way | 7 | 30th December 2010 05:27 PM |
| Looking for a replacement for Maggies, suggestions wanted | EEatKSU | Full Range | 14 | 19th December 2007 11:42 PM |
| Dalesford Bass Driver - Any suggestions for a replacement? | MCH786 | Multi-Way | 2 | 1st January 2007 03:25 PM |
| Suggestions for CD960 audio out cap replacement | @lf | Digital Source | 10 | 10th November 2006 02:54 PM |
| 5533 replacement suggestions? | ubertar | Chip Amps | 0 | 26th August 2004 01:15 AM |
| Page generated in 0.18521 seconds (43.31% PHP - 56.69% MySQL) with 10 queries |
