ClassA mosfet p/p amp with no feedback? - diyAudio
Old 17th June 2003, 01:12 PM   #1
nobody special's Avatar
Question ClassA mosfet p/p amp with no feedback?
Is it possible to build a stable mosfet push pull amp without feedback? I have a couple questions on something I was attempting to design.
My simulation consisted of a differential pair on the input, folded cascode, with a Vgs multiplier, driving a push-pull output stage biased into class A.
I was altering the dc offset using the current source on the differential amp. Is there a better way to set the output stage to 0V? question #2- is thermal drift a problem with this type of an amp, and how would you go about controlling it?
I would like to understand this type of circuit better. My ultimate goal with this is to mirror the cascode and output stage on the other half of the differential pair to form a push-pull X (super symmetry) amp, but I want to understand the basics first.
Any helpful hints?
Steve
Old 17th June 2003, 02:40 PM   #2
PMA is offline PMA  Europe
PMA's Avatar
In fact every circuit has some kind of feedback. You probably mean global negative feedback from output to input. Even a voltage follower has a 100% local feedback. Some other circuits may have different local feedback. You can distinguish between serial, parallel, voltage and current feedback.
Old 17th June 2003, 03:10 PM   #3
yeah... I know what you mean. I was talking about global negative feedback.
Steve
Old 17th June 2003, 03:16 PM   #4
Maybe the experts will disagree, but IMHO it should generally
be easier to make a non-NFB amp stable. Although you might
still get instability from local feedback loops (deliberate or
parasitic) and interstage phenomenae, global feedback is
the main reason for instability problems.
Old 17th June 2003, 04:11 PM   #5
I guess I was thinking more of the output stage drifting... dc levels of the whole amp shifting around. I thought that feedback helped control that kind of thing. At least without GN feedback I won't have to worry about oscillation (other than from poor layout).
Steve
Old 17th June 2003, 04:29 PM   #6
Ah, that's a different story. Yes global feedback is usually
exploited to reduce the DC offset. Unless you are using
coupling caps within the amp, you actually could have a DC-only
global feedback for this purpose, ie. a feedback network
with a very-low-frequency lowpass filter, if DC is a problem.
Hm, rereading what you wrote, well you can't really control
the various DC levels in the amp separately by feedback, so
that is a problem you have in either case.
Old 17th June 2003, 04:47 PM   #7
Would that be considered a servo?
Part of what I liked about the design was that it is basically a single voltage gain stage with a follower, if you consider the cascode to be a single gain stage.
Steve
Old 17th June 2003, 04:50 PM   #8
joensd is offline joensd  Germany
Here are some class A designs that might inspire you.
"Thierry Gibouins single ended" looks like a NFB design.
Would be interesting to know how good such a simple circuit works...
Jens
Old 17th June 2003, 05:00 PM   #9
Thanks for the link. I'll check it out.
Steve
Old 17th June 2003, 05:30 PM   #10
No, it's just global feedback of DC (and very very low frequencies).
The difference, in my understanding, is basically that a servo
uses an active element, usually an op amp, to form a active low
pass filter, to do the same thing.
SE J/MOSFET Class A Amp, no Feedback widowmaker Solid State 5 11th July 2013 06:38 PM
Tube Pre Amplifier for SEWA 7 Watt ClassA MOSFET lineup Tubes / Valves 278 2nd June 2009 04:44 PM
Power DAC for for SEWA 7 Watt ClassA MOSFET amp Tyimo Digital Source 4 28th November 2006 12:40 PM
Cascoded -MosFet- Zen without feedback Tyimo Pass Labs 17 7th February 2006 12:40 PM
Copyright 1999-2017 diyAudio
