ESP 3A output power at 4 ohms load - diyAudio
Old 17th June 2003, 11:59 AM   #1
Freddie is offline Freddie  Sweden
Default ESP 3A output power at 4 ohms load
Just measured the output power of my my modified ESP3A amplifier.. Using two pairs of 2SA1216/2SC2922.. Powersupply consists of a 500VA 2*38V toroid transformer, and two 47000uF RIFA caps.
The results into 4 ohms load was:
28,3V RMS, I = 7A (It starts to clip just above this voltage)
So output power is about 200W.. I would have expected slightly more.
Supply voltage (no load): +/-53,6V
Supply voltage (full load): +/-49,6V
So is this normal.. It seems like it only can swing +/-40V.
/Freddie
Old 17th June 2003, 12:41 PM   #2
The collector resistors of the CFP outputstage is 0,47 ohms.
7A and 0,47R means that I will lose over 3V across those resistors.
Perhaps the output power is reasonable after all.
Think I will reduce those resistor to 0,15R.
Anyone else measured the output power of their ESP 3A?
/Freddie
Old 17th June 2003, 01:46 PM   #3
Account Disabled
will that drive up the bias?
Old 17th June 2003, 02:56 PM   #4
It will if I just lower the value of the resistors, but I will readjust the bias to have 100mA.
Old 18th June 2003, 08:36 AM   #5
Jean is offline Jean  United States
Jean's Avatar
Send a message via AIM to Jean
Hello Freddie,
Did you measure it into a resistive load ? Also for how long ? I would be interested in more specifics of what other components you had to change from the original p3a schematic .
left lane is for passing, slower traffic keep right please.
Old 18th June 2003, 08:52 AM   #6
Did you measured it into a resistive load ? Also for how long ? I would be interested in more specifics of what other components you had to change from the original p3a schematic .
Yes, I measured power into a 4 ohm resistive load for a couple of minutes. The 4R resistor got quite hot! Otherwise no problem at all.
Q1, Q2, Q3, Q9 = 2N5550
Q4 = MJE350
Q5 = MJE15030
Q6 = MJE15031
Outputstage transistors = 2 pairs of 2SA12116/2SC2922 (each with a 0,1R emitter resistor)
R9, R10 = 3k3
Q4: Needs a small heatsink
Q5, Q6 : Need a small heatsink
Q9 mounted (glued) at the top of Q5 to create a stable bias current.
/Freddie
Old 18th June 2003, 11:47 PM   #7
blmn is offline blmn  Brazil
blmn's Avatar
Freddie
I think you have to consider the voltage drop on the 0,47R is a function of the peak current (near 4,7v over the resistor). You have 49.6Vcc at full load minus 4,7v. Since you have 39.9v peak and 44.9 available to swing I think you´re reaching a reasonable power level in this case. Did you measure the Vcc at full load using the scope or the DMM?
Old 19th June 2003, 08:38 AM   #8
I measured Vcc at full load using a DMM. But I think I will reduce the value of the 0,47R resistor, perhaps to 0R1.
/Freddie
Old 14th December 2003, 09:26 AM   #9
MaXiZ is offline MaXiZ  Italy
MaXiZ's Avatar
Send a message via ICQ to MaXiZ
Excuse me... from which u say the schematic have modifyed... how? ANd is there a substitute to MJ? Here in italy are very EXPENSIVE (the 2sc too... 17€!)
Old 14th December 2003, 12:13 PM   #10
I haven't got the schematic left, but here are the changes I've done to the P3A amp. Yes the 2SA1216/2SC2922 are expensive. Try MJ15003/15004, they are cheap.
/Freddie
Powersupply/channel:
One 500VA toroid transformer
Two 47000uF 63V RIFA capacitors.
Amplifier:
Q4 = MJE 350
Q5, Q6 = MJE1503x
I use two pairs of Sanken 2SA1216/2SC299 transistors each with a 0R1 5W emitter resistor.
R9, R10 = 3k3
Q4, Q5 and Q6 need to have small heatsinks.
I also placed Q9 (Vbe multiplier) at the top of Q5 to have a very stable bias current.
Power load, dummy load (pic) luka Power Supplies 43 9th February 2012 03:50 PM
SE load mismatch, 8 or 6 or 4 ohms? flysig Tubes / Valves 3 9th May 2009 07:15 PM
Can this set up increase the output power of LM1875 at 4 ohms?? Leolabs Chip Amps 7 25th November 2007 12:29 PM
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 06:17 AM
ISOBARIC 16 ohms load powered by 8 ohms Amp eddi0 Subwoofers 24 21st October 2006 04:29 PM
Copyright ©1999-2017 diyAudio
