My ARC SP-6A need to be repaired :
- the first regulator Q1 ( a Motorola MJ410 ) is out and its emitter resistor ( located on its right ) is burned,
- I hope there is only that !
My problem to solve :
- I am unable to know ( due to smoky color codes ) the value of this burned resistor,
- my reading is 362 ohms, but I think it is wrong,
- If I consider SP-6 diagram this is a 1kohms carbon resisistor,
- but I don't know if this value is the same for my SP-6A.
Please, I need your help :
- the best for me would be to have SP-6A diagram,
- or possible to give me color codes on it if you know that.
Thanks to You,
Raymond
For you below, this Q1 regulator, and just on its right side the burned R :
Thanks to You,
Raymond
1K in the SP-6.
Bill
Thanks Bill for your interest !
- 1K for the SP-6, I know,
- but for the SP-6A, how much ?
Raymond
You may find the info you need here; ARCDB.
Dave
Thanks Dave.
Of course I know.
But alas, there is no diagram for SP-6A !
Raymond
Q1 in the SP6A is an MJ413. Q2 and Q3 are MJ410. Q1 doesn't have an emitter resistor, the emitter goes right to the collector of Q2, to an 18k resistor feeding a zener string (the voltage reference for Q2), and to a 1k8/1W resistor which is part of an RC filter. Q2 has an emitter resistor of 1k/1W. Q3 has an emitter resistor of 10k/1W.
Frankly, it's a very crude, low performance regulator. I'd replace it completely with a cheap Maida or a two transistor feedback regulator, either one using a MOSFET pass device.
Q1 in the SP6A is an MJ413... ...
Thanks SY for your explanation !!!
I just send you a message by e-mail.
Raymond
- AUDIO RESEARCH SP-6A schematic
