Insulation between case and RCA jacks
Old 26th April 2010, 04:10 PM   #1
deniss77 is offline deniss77  United States
Default Insulation between case and RCA jacks
I'm going to customize my Onkyo A-RV401 integrated amp to include pre-outs and main-ins, so that I could use it as a stand-alone amp.
My question is - is there any reason for insulating RCA jacks from the chassis? The factory jacks (all analog signal) have a plastic buffer between RCA jacks and case, but I was going to buy standard RCA jacks with an all-metal jacket (like PartsExpress sells), so they would bolt to the chassis sheet metal.
Since the ground for RCA jacks should be same as common ground, I figured there's probably no need for insulating the jacks from chassis, but I wanted to ask just so make absolutely certain.
Old 26th April 2010, 05:02 PM   #2
jcx is offline jcx  United States
if the manufacturer insulated I expect there were ground loop noise/hum issues and would expect you should use insulated jacks as well
Old 26th April 2010, 05:12 PM   #3
stoc005 is offline stoc005  United States
stoc005's Avatar
Parts Express has some reasonably priced insulated RCA chassis mount jacks. Around 6.50 USD per pair.
Old 26th April 2010, 06:21 PM   #4
I betcha they insulated for ease/cost of manufacture. The jacks look like they are molded to a large plastic plate as a large cluster, which was probably easier for assembly purposes, and then the plastic plate is mounted to chassis instead of each jack individually. So it's difficult to say whether they insulated because it's better for sound or because it's better for cost.
I'll go ahead and use insulated jacks then, just to be on the safe side.
Can anyone suggest a good way to connect pre-outs to main-ins if they need to be shorted for default operation? I've seen "linking plugs" used in amps that come with built-in pre-outs and main-ins - are those available commercially, or would I just use extra-short RCA cables?
Old 26th April 2010, 06:34 PM   #5
fastbike1 is offline fastbike1  United States
You can just use a short piece of #8 solid copper wire. Fits the RCA just about perfectly.
I was so much older then, I'm younger than that now.
Old 26th April 2010, 08:25 PM   #6
jaycee is offline jaycee  United Kingdom
They are insulated from the chassis to avoid ground loop problems. If you dont do this with your replacement jacks, then it is highly likely that your amp will have hum.
Old 26th April 2010, 08:37 PM   #7
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
Exactly. It is better to have case ground and audio ground separated but for only one point in the case.
A little OT: despite being done less optimal than possible in a lot of gear by connecting them simply directly together there is a better old fashioned method when one cares for audio quality:
If you connect audio ground to case/safety ground ( the one where the wall outlet "earth" is connected to the casing of the amp ) with a 100 Ohm 1 W resistor paralleled with 22 nF 250 V ceramic cap you will have "isolated" and at the same time "connected" the audio ground that you want to keep clean with the safety ground that you need for safety... No injection of rubbish into audio circuits possible from safety earth/ground....No hum....Still RF protected.....Still safe....No ground loop....
It's only audio. Member of the non modular PCB design committee
Old 26th April 2010, 08:52 PM   #8
This is very useful info - thank you for posting this. Now it makes sense why in my vintage Kenwood amp all RCA-jack grounds have those ceramic caps on them before going to case ground.
I purchased insulated RCA jacks based on all the input here.
Somewhat OT... For connecting wire inside the amp where I need to make splices and runs to the RCA jacks and back, I am going to use solid-core wire... Should it be something like 18 or 20 AWG?
Old 26th April 2010, 10:09 PM   #9
kevvywevvywoo is offline kevvywevvywoo  United Kingdom
I agree, you may get an annoying ground-loop hum as you will be grounding the rca inputs at the pcb and also at the chassis. Insulated RCA inlets are cheap enough.
Old 26th April 2010, 10:16 PM   #10
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
It depends on your source.
If it is not connected to earth then you really need the amp input earthing.
If the source is earthed then you dont need the input to the power earthed as it iwill likely cause hum.
As I connect all sorts to my amps I have a switched earth on the input to my amplifiers.
PCBCAD51 pcb design software. 2018 version out now. https://www.ebay.co.uk/sch/i.html?_f...nload&_sacat=0
Insulation between case and RCA jacksHide this!Advertise here!
rca jacks reddish75 Digital Source 2 24th September 2006 06:53 PM
Question about using RCA jacks. G Tubes / Valves 28 1st December 2004 10:36 AM
Cardas RCA jacks cadmaniac Swap Meet 31 29th January 2004 09:43 PM
1/4" vs rca jacks AJ Bertelson Pass Labs 10 16th March 2003 06:08 PM
Can't find RCA jacks Roepke Everything Else 4 4th April 2001 02:30 AM
