Old 23rd April 2010, 08:02 PM   #1
Default I build my JLH amplifier...
Today I am start building my JLH power amplifier. I bought on eBay two PCB for voltage regulator. Please look PCB and heatsink placing and screw for mounting. I think use ultra fast diode (not schottky) Please help me select shunt capacitors for this 8 diode in parallel. What is better ceramic C0G, NP0 or Wima MKS polyester capacitors?
Old 27th April 2010, 03:14 PM   #2
Please help me select Capacitors. C0G NP0 or WIMA MKS2 polyester?
Old 27th April 2010, 06:11 PM   #3
Mooly's Avatar
I'd stick with polyesters... stability and tempco just doesn't matter here. Make sure you get a high enough voltage rating, and the correct lead pitch to fit the pcb... and without knowing the circuit can't tell you what that voltage rating would be.
A simulation free zone. Design it, build it, test it.
Old 27th April 2010, 07:06 PM   #4
Bigun is offline Bigun  Canada
Bigun's Avatar
my 2c: For shunting rectifiers in the psu you are probably not needing something exotic - multilayer ceramic should be perfectly good. Buy from a reputable place, there's a lot of junk on the market and supply chains in the electronics industry are strained in certain areas.
Note that multilayer ceramic should not have the self-oscillation problems of the single layer devices.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 5th May 2010, 04:06 PM   #5
I think what I use WIMA MKS2 0.1uF capacitors
Old 15th June 2010, 07:13 PM   #6
I use LT1083CP in TO247 package what is better for this case ceramic or silicon thermalpad?
Old 22nd July 2010, 03:13 PM   #7
U buy 10n C0G capacitors for this board. My first step Cap mounting...
Old 22nd July 2010, 07:28 PM   #8
Greg Erskine's Avatar
Very good looking PSU board.
Metal standoffs look dangerous on the right hand side (third picture).
regards
Greg Erskine
Old 22nd July 2010, 07:35 PM   #9
I not use this standoffs it's only for soldering. PCB not have copper around the holes.
My second step diode mounting...
Old 28th July 2010, 07:33 PM   #10
I mount heatsink and AC power input connector to PCB
JLH headphone amplifier steveh49 Headphone Systems 7 5th September 2011 05:05 AM
JLH 10 Watt class A amplifier DomKo Solid State 3 18th November 2003 06:32 AM
JLH Amplifier dhengkoel Solid State 0 24th November 2001 05:53 AM
JLH Quad esl's amplifier version M.H.Cormier Solid State 4 16th November 2001 11:56 PM
JLH Class-A Amplifier Geoff Solid State 5 25th May 2001 11:55 PM
Page generated in 0.10316 seconds (79.24% PHP - 20.76% MySQL) with 11 queries
