Old 16th June 2003, 11:24 PM   #1
Diode is offline Diode  United States
Default Soft start circuit
Hi all,
I'm sure that this topic has been well covered but to save time in search, I have seen soft start circuits that use one or two MOVs that later get shorted by a relay for full power. I'm looking for a simple circuit that is reliable and places to get parts.
My circuit will be powering an old Peavey transformer from a PV .75K amp that produces 2X +/- 53VAC, current unknown but it powers 2X350WRMS power amps. I will be rectifying both sets of windings and then parallelling them for a 500W amp I'm building. I will have 40,000uF of filtering per rail so I need a good circuit to soft start with.
Can someone please help?
Thanks in advance,
Chris
The best audio is clean audio!
Old 17th June 2003, 07:24 AM   #2
EchoWars's Avatar
Why an MOV? If you are going to short across it, then a decent power resistor will be fine, and IMHO, probably more reliable.
I have built this circuit and added it to several amps. The resistor is an Ohmite 89-Type, aluminum axial, from Digikey.. Very small, very tough.
I show a DPDT switch, with a resistor to discharge the caps. Not necessary in all apps. I also show the relay coil being powered from both rails. Not very efficient with high rail voltages, but keeps current draw even....if these are high-power amps, a 110VDC relay might be a decent idea...less wasted power.
Old 17th June 2003, 07:28 AM   #3
EchoWars's Avatar
BTW, I lucked out finding a couple of good relays at a local surplus shop. I need more, and am SOL so far. If you find a good source of (preferrably) 48VDC relays, I'd like to hear about it.
Old 17th June 2003, 07:38 AM   #4
Electrons are yellow and more is better!
peranders's Avatar
The solution will work but have two disadvantages:
1: Slow reset. Sometimes you get a rather short dip in mains volatge, this can create a heavy current spike (if you use a toroid) even if the smoothing caps are charged.
2: Not allowed in Europe due to safety reasons if you mix mains circuit and secondary side in the same relay. If you choose this solution you must use a relay with increased isolation, for instance ELESTA SIRxxx types
/Per-Anders (my first name) or P-A as my friends call me
Old 17th June 2003, 08:26 AM   #5
EchoWars's Avatar
Huh? And the spike is smaller with no soft-start?? This sentence makes no sense...perhaps you would care to elaborate...
He's in Oklahoma. We got half the line voltage you all do.
This is a very commonly used circuit...stolen from an 'audiophile' amp. No magic here. It would be nice to find a decent relay, and a high isolation wouldn't hurt, but most of the HI relays are excessively large. If you got the room, then sure... But for me, at this point anyway, any suitable high-current relay of 48V or better seems to be damn near impossible to find.
Old 17th June 2003, 08:30 AM   #6
matth is offline matth  United Kingdom
matth's Avatar
What about this cct. I have made a couple of these and they work great.
http://mitglied.lycos.de/Promitheus/...or_toroids.htm
Old 17th June 2003, 09:12 AM   #7
Helix is offline Helix  United Kingdom
Helix's Avatar
I have built several of these Elektor in-rush limiters, from 300 to 750 watt trannies with large cap. banks, no problems so far (3 years)
Ted
Old 17th June 2003, 09:26 AM   #8
HighTec is offline HighTec  Croatia
HighTec's Avatar
Hi.
Now it's my turn.This is soft start unit I used in projects with Holton's AV400 modules.The schematic is stolen from Elliott's pages,but I've added some things from a professional unit.
As you see there are two relays.Relay 1 shorts the parallel resistors and he acts in approx. 1,5 sec delay.The relay two acts immediately.In fact he is the main switch and you don't need to use those 10-15A switches.The relays are 12V type.
F2 is a thermo fuse.He blows if Rel 1 fails.The fuse is mounted between the R8 & R9.There must be a contact with them.The best way is to stick them together with a plastic strap.
Q2 is BUZ71.A much less powerfull transistor can do the job very well.I've used this mosfet because I have a whole bunch of them.
Bellow is the schematic and the PCB(in case you decide to build it)
Regards.
Old 17th June 2003, 09:29 AM   #9
HighTec's Avatar
And the PCB.
Bottom layer:
Old 17th June 2003, 09:34 AM   #10
HighTec's Avatar
Top silkscreen:
ESP soft start circuit 454Casull Power Supplies 19 29th May 2009 02:06 PM
soft start circuit tsearay Swap Meet 0 8th February 2007 01:18 PM
Soft start circuit for GainClone markiemrboo Chip Amps 23 25th October 2006 05:30 PM
Soft start & Soft Switch circuit: can anybody help? m.parigi Solid State 95 22nd August 2005 03:32 PM
ESP Soft Start Circuit Alcaid Parts 4 25th February 2005 06:56 PM
Page generated in 0.11638 seconds (75.99% PHP - 24.01% MySQL) with 11 queries
