Soft start circuit - Page 2 - diyAudio
Old 17th June 2003, 12:07 PM   #11
trwh is offline trwh  United Kingdom
trwh's Avatar
Diode,
http://sound.westhost.com/project39.htm
Old 17th June 2003, 12:10 PM   #12
trwh's Avatar
You can see my implementation of this circuit here:
http://www.diyaudio.com/forums/showt...0187#post50187
Works well so far. I second EchoWars' recommendation to use a power resistor in stead of a MOV.
See ya,
Tim
Old 17th June 2003, 12:15 PM   #13
trwh's Avatar
Echowars,
Huh? And the spike is smaller with no soft-start?? This sentence makes no sense...perhaps you would care to elaborate...
What Peranders said made sense to me. He is saying that the circuit that you posted will take an appreciable time to reset itself when the mains is disconnected. This delay means that in the event of a momentary mains power failure, the circuit may fail to reset and the soft start action would not be present. Other, more involved (active) circuits may have quicker reset times and hence avoid this problem.
Tim.
Old 17th June 2003, 12:20 PM   #14
HighTec is offline HighTec  Croatia
HighTec's Avatar
Yep,that's right trwh.
Old 17th June 2003, 09:59 PM   #15
EchoWars's Avatar
Diode posted:
I'm looking for a simple circuit that is reliable and places to get parts.
Emphasis mine. I tried to provide exactly what he asked for. Start planning for all contingencies and suddenly simplicity is out the window.
trwh, I like that circuit, and I may well use it on another project. But it is not exactly simple (but it is well done).
Edit: Certainly the power switch and bridge ought to be decent enough to be able to handle turn-on without the soft start, otherwise it is simply poor design. An occasional power dip resulting in the loss of mains voltage requiring the recharging of the bridge and filter caps should not be a problem, and if this is a frequent occurance, then you've got more problems than the need for a soft-start circuit...
Old 18th June 2003, 01:52 AM   #16
Diode is offline Diode  United States
WOW!
Thanks all for the information. I had seen the ESP design but wanted to see others and get different opinions. Yes, I have also seen to add a seperate power supply for the relay ckt. I will have a 12V PS for my speaker protector already so that's good!
The reason I mentioned MOVs was I worked for a power supply manufacturer and they used MOVs with a relay for their inrush ckt. Also Peavey uses MOVs on a big amp of theirs as well. I just haven't studied the circuit yet.
So many choices!!!! Jeez, next, I want to build a variable limiter.... I can't imagine how many different circuits there will be...
Keep the ideas coming if you wish. I use 120VAC in America though.........
Thanks to you all!
Chris
The best audio is clean audio!
Old 18th June 2003, 02:03 AM   #17
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Who designed this.?
Old 18th June 2003, 02:50 AM   #18
JojoD818's Avatar
matth,
can I use the Elektor soft start for 220VAC?
jojo
Old 14th January 2013, 08:22 PM   #19
Electrons are yellow and more is better!
peranders's Avatar
Originally Posted by HighTec View Post
And the PCB.
Bottom layer:
Wow, dangerous pcb. Creepage distance almost zero.
Old thread, I know.
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 14th January 2013, 08:38 PM   #20
HighTec's Avatar
Did you first remove the dust from this thread in order to post? Ok, that PCB was designed back in 2001. Anyways, if you apply the soldermask then there is no fear of jumping sparks between the copper traces. Well, I'm more mature now and my PCBs are more mature now as well.
Edit: the distance between traces was 30 mils. Maybe the low picture resolution makes it look closer.
ESP Soft Start Circuit Alcaid Parts 5 29th October 2014 01:11 PM
ESP soft start circuit 454Casull Power Supplies 19 29th May 2009 03:06 PM
soft start circuit tsearay Swap Meet 0 8th February 2007 02:18 PM
Soft start circuit for GainClone markiemrboo Chip Amps 23 25th October 2006 06:30 PM
Soft start & Soft Switch circuit: can anybody help? m.parigi Solid State 95 22nd August 2005 04:32 PM
Copyright ©1999-2017 diyAudio
