#381 |
>You can also see the square wave output is higher at 1MHz than the sine wave at 1MHz (why is that? output transistor input capacitance? diff amp capacitance?)
The fundamental sine of a square wave is 4/pi times higher, see: Square wave signals : MIXED-FREQUENCY AC SIGNALS I will answer the other questions later. Sorry, I have to go now. edit: I'm back as there's a strike going on in Amsterdam. Cheers, E.
Een volk dat voor tirannen zwicht, zal meer dan lijf en goed verliezen dan dooft het licht…(H.M. van Randwijk) Last edited by Edmond Stuart; 20th November 2011 at 12:16 PM. |
#382 | |
When I look at my scope output with the bandwidth reduced 20MHz (it's the only filter available to me) I usually see 2mVpp to 5mVpp as typical wideband noise. |
#383 |
>then the ratio of the two figures is ~50, rather than the >=3 that you mentioned.
Of course the ratio seems much higher because the picture is highly distorted by HF ingress.
Een volk dat voor tirannen zwicht, zal meer dan lijf en goed verliezen dan dooft het licht…(H.M. van Randwijk) |
#384 |
thanks for the picture as it pleases me to see the trace is nearly identical.
I made a picture myself too. Check it out. But I need to say, this is done with grounded input. If I leave the input flying or if I connect it to the generator (even if switched off) the figure is roughly 10x worse. In the case of a flying input there is 600KHz signal prominently apparant. In the case (picture) of a grounded input there is a sum of 2 thing. An amount of 600KHz signal and another amount of around 30MHz signal. There is always a very weak amount of 50Hz too. Not really as a signal but more like repetitive small spikes. I gues it's some battery charger or so... Cheers, Olivier |
#385 | |
What is the difference when we are looking for the quietest output that the circuit is capable of? |
#386 |
The difference is that we are talking about two different noise sources: one that is generated by the amp itself and the other picked up by an unshielded speaker cable (or whatever) from outside noise sources. I'm afraid I'm missing your point.
edit: the reason I've included a scope picture is to make clear that without rigorous precautions the noise floor is always blurred by external sources and to make clear that Olivier's 2mV noise is nothing to worry about.
Een volk dat voor tirannen zwicht, zal meer dan lijf en goed verliezen dan dooft het licht…(H.M. van Randwijk) Last edited by Edmond Stuart; 20th November 2011 at 01:09 PM. |
#387 | |||||
I put there 100 Ohms, because I thought you didn't like empty spaces. The actual value is absolutely not critical, though the lower the better.With 1k it oscillates? Measured with a 1:1 probe? If so, that means trouble. Always use a 10:1 attenuator probe. Quote:
Regarding the choice of output devices, both verticals and laterals have their pros and cons. Verticals can deliver more power, but need beefier drivers, gate protection Zeners and temperature compensation. Of course it's up to you which one you prefer and (of course) which one you can get. The best verticals for audio are 2SJ201 and 2SK1530. Regrettably, it is said that Toshiba has discontinued the production of 2SK1530. Cheers, E.
#388 | |
In order to measure the real noise (and no rubbish from broadcast stations) you must shield everything, also the PCB. (and ground the input) Good luck. E.
#389 |
Good evening Edmond,
I have noticed some other changes in the schematic. Could you tell me why the change is made? 1) the diodes in the diff amp, right legs, are replaced by zener diodes D3/4 value 4V7? 2) The resistors in the current source legs are replaced by zeners D5/6 value 4V7 (you already mentioned this change)? 3) The feedback capacitor had a parallel leg which included a polypropylen capacitor. Is it useless or just deleted for simulation purpose? 4) The sequence of connection to the rails of the decoupling capacitor is particular. Is that how it should be intended on the PCB too? First it is placed between the VAS and IPS. Second, the RC filter between VAS and IPS is right in between both decoupling capacitors (the electrolyt C12 and the non polarized smaller one C8). 5) The non polarized caps are 10 fold larger. Is this really better? 6) C6 and C7 are of different value? I suppose it's a copy paste error. 7) Q21 and Q22 are 2N5551 & 2N5401 Q's whereas it was 2SC3503 and 2SA1381. In my circuit the developped power is very limit. In yours the power is lower. Why lower? Better lower? 8) Zeners D11 & D12 are changed from 6V2 to 4V7 equal to the cascode zeners. I made them slightly higher in order to be sure the cascodes cannot saturate. Is that wrong thinking then? 9) C17 A & B are removed. Are they useless? I suppose we could replace all or most zeners by voltage references? As for the OPS devices lets keep them Laterals 1058/162. The only bummer is the voltage limit 160V :-( I will also look for higher voltage devices. By the way what do you think of IRFP9240? Is vertical mosfet. Cheers Olivier |
#390 |
Hi Olivier,
Answering all these questions is a long story. May I propose to do this later? First thing first and that is simulating the Miller loop response in a correct way. edit: This has to done right, otherwise it makes no sense to go any further (see post 373). Cheers, E.
Een volk dat voor tirannen zwicht, zal meer dan lijf en goed verliezen dan dooft het licht…(H.M. van Randwijk) Last edited by Edmond Stuart; 20th November 2011 at 09:28 PM. |
| Randy Slone 6.6 design | py | Solid State | 8 | 20th July 2011 02:06 PM |
| Randy Slone Passes | Bluetron | Solid State | 51 | 8th January 2011 10:05 AM |
| Randy Slone | JDDCo | Solid State | 6 | 22nd September 2006 02:57 AM |
| Randy Slone: Opti-MOS | pixie | Solid State | 73 | 12th September 2004 07:57 AM |
| OPTIMOS-Amp from Randy Slone | wopo | Solid State | 1 | 12th July 2004 08:18 PM |
