Audio Junkie
I am looking to calculate the gain of this single Jfet amp stage. I found this previous thread:
Have to calculate gain for typical small JFET preamplifier and using the simplified version of John Curls calculations: Vg=R(1)/{R(2)+1/Gm} or R(1)/R(2) approximately R1/R2 = gain I find that we have about 6K/12K = gain of 2 or 6db Correct? seems to make sense. Zc |
#2 |
Audio Junkie
I am hoping someone can confirm my math here?
#3 |
Did it Himself
Yes, 6k in the source and 12k in the drain would yield you gain of 2 when output is taken from the drain and loaded with a reasonably high impedance (10k would be fine).
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#4 |
Audio Junkie
Thank you!
#5 |
Did it Himself
Remember that the output will be inverted with respect to the input, so you may want to include another stage or simply live with it.
#6 |
Audio Junkie
This is actually part of a GK 1001RB bass amp. This Jfet is in there for flavor only from what i gather. there is an op-amp before and an op-amp after so this Jfet really doesn't DO anything other then overload and change the sound. But once i started looking at the circuit i got curious as to how much gain it was providing. I didn't figure much if any at all.
#7 |
That's a simple common source stage, for the basic euquations look in wikipedia:
Common source - Wikipedia, the free encyclopedia R1/R2 = gain is a bit too simplified as the jfet itself does not matter at all and of course there are high gain (transconductance) and low gain parts ![]() Also, 6k in the source are a little...uncommon. You will be driving any small signal jfet near pinch-off voltage limiting signal swing. Better try smaller source resistor and smaller load resistor. Have fun, Hannes EDIT: just thought over your last post: sure, that's ok if you want to add sound to the circuit
| JFET Lineamp with Gain | wrenchone | Solid State | 31 | 24th December 2010 09:15 AM |
| Mastroianni Single JFET Input Preamp | lineup | Solid State | 18 | 4th June 2007 06:46 AM |
| Have to calculate gain for typical small JFET preamplifier | supernet | Solid State | 4 | 11th August 2006 11:22 PM |
| single JFET as volume control | Leolabs | Solid State | 1 | 13th December 2005 03:59 AM |
| Page generated in 0.08880 seconds (74.49% PHP - 25.51% MySQL) with 10 queries |
