Dx Troyan, a 650 watts channel amplifier.
Closed Thread
Old 6th October 2010, 07:37 AM   #281
ostripper is offline ostripper  United States
ostripper's Avatar
Originally Posted by AndrewT View Post
don't be sorry for not being precise in your selection of components. There is no reason to appologise.
But, be unambiguous when you tell your readers what you recommend.
As you can see "match transistors" means something completely different to different people.
"What you put in is what you will receive at the other end" On one amp I did not bother to closely match devices ... amp worked (well ??), but Re voltages were less than ideal ( 15mv , 18mv ,14mv). On newer amp, just using a DMM selected 16 out of 30 devices that were "close" .. now ALL Re's are 15mv I do not think this made the amp sound better but it might be more reliable in the long term.
Just a consideration when building a high powered amplifier with many paralleled pairs.
Input devices also follow this line of thought. If you can find 2 that are "close" with the DMM you will have a output offset of <10mv BEFORE having to adjust a trimmer. This actually MAY influence the final sound .
OS
Wanderer - my travels.... Facebook - davyjones lockre -
Old 6th October 2010, 06:31 PM   #282
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default I am still playing with the Troyan..now playing with a voltage regulator
Enjoy the video and the picture:
YouTube - Supply, part 3 - Still playing with the regulator
regards,
Carlos
Restriction removed ; ttps://www.youtube.com/watch?v=3ioyOjAzDt0; https://www.youtube.com/watch?v=uFcnddpe3MU
Old 11th October 2010, 09:08 PM   #283
Default I have discovered the way to make it sound awsome
Interesting.... a non standard modification that may drive technocrats crazy... well..they will never know..they are not builders.
Now it is playing with astounding, awsome superior sonics.
Will inform only to builders.... to avoid troubles...the modification is really crazy.
aahahahahahah!
regards,
Carlos
Old 16th October 2010, 03:29 PM   #284
norazmi is offline norazmi  Malaysia
hi there,
Uncle Charlie can u send me an email for this construction of troyan, schematics, PCB, silk if u have the final one all of these, i would like to build it now. my email xwebmaster at gmail dot com. THIS IS MONSTER AMP!!
Regards.
Azmi.
Old 16th October 2010, 03:33 PM   #285
for the power supply, ill use offline smps by LUKA, already made 1 and working good, rails can be adjust by rewind trafo, maybe i can get 1kw of this smps, tested with dx amp before working great ..
Regards.
Azmi.
Old 16th October 2010, 04:44 PM   #286
tryonziess is offline tryonziess  United States
Carlos,
I am not one of the complainers. Please send me all of your modifications. I think I will put this together. I have about 32 nice 100 volt caps and some nice 1kw trannies.
How much welding cable do you think I will need? Joking here.
I also have some 10 nice Rifa 450 volt oil filled caps if anyone is interested. They are real nice. It takes a slew of bridge rectifiers in parallel to charge them.
Tad
Old 16th October 2010, 05:06 PM   #287
Default All i know from this amplifier was posted Azmi....i cannot remember details
So, the effort for you to read will be the same effort for me to read.
Please, give a good read into this thread in advance to move... this amplifier is not easy.
I am very busy with the new amplifiers to be released, so, i will be happy if you do some effort to read, avoiding me to read the thread to remember and then go to explain you.... do not make too much sense if you can read by yourself saving from uncle charlie some effort and also saving my time and energies... as i have already spent a lot creating it, simulating it, building it and testing it..not your turn folks.
I am glad about your interest friends, but this amplifier was posted so long time ago that i cannot remember exactly....reason why i have posted all things that happened.... the thread is the memory for us..... alike you dear Norazmi...i will have to read the thread entirely to understand it deeply... as i said...i'm doing other things...i would like to be free to finish the stuff i have to do.
Modifications are easy, two parts to change..so...first build it..then after built i will inform you what parts to remove and change value.... will not inform in advance..no way.
regards,
Carlos
Old 16th October 2010, 06:17 PM   #288
Sure Uncle Charlie, im reading on it , take ur time first ill carefully build this one as you mention above, hihihi dont worry be happy uncle Charlie
Azmi.
Old 16th October 2010, 07:52 PM   #289
Nico Ras is online now Nico Ras  South Africa
Nico Ras's Avatar
Default Adding a Busbar
Carlos,
Congratulations with your new design. I trust that the builders will enjoy this one as much as they did all your previous designs.
I would like to make one recommendation in that you remove the soldermask from the power lines so that the constructor can solder a copper busbar (see attached picture).
I have found this necessary on high power amps laid out this way. as there is a considerable voltage drop across the PCB track from the first to last transistor and you find the first works harder than the last.
Kindest regards
Nico
Old 16th October 2010, 07:58 PM   #290
Nico Ras's Avatar
Here is a better view
Nico
Closed Thread
Dx Troyan, a 650 watts channel amplifier.Hide this!Advertise here!
zeta 500 watts n-channel amp pcb need ashokavarthanan Solid State 0 1st October 2007 03:10 PM
Fender/Sunn SA6520P 6 channel powered mixer 520 watts dhardinger Instruments and Amps 0 12th April 2007 11:10 PM
