Dx Troyan, a 650 watts channel amplifier.
Old 14th August 2010, 05:05 AM   #221
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Well dear friends, uncle Charlie is back again.
The misunderstanding was caused by my mistake.
The schematic does not show the correct part really used in the prototype...i have always used MJE15032 transistor for first and second VAS.... my intention was to replace but i have not another transistor for that position...soon i will have, as Evette from Canadá is sending me hundreds.
Old pictures posted in this thread may show you the second VAS big heatsink and you may see the MJE15032 in the first VAS position.
This was the trouble.... the prototype was using MJE15032 and i made the first mistake, posting a schematic from my simulator (generated by simulator and converted in pdf) showing the BC840.... this unit was just to make tries to see if i could find a transistor that could help me to reduce THD in the simulator analisis....i knew it could not face the voltage....was a try only and by a mistake it was shown in the schematic diagram.....gladly no one have built.... that transistor would not work there..it is a low voltage unit.
Then i made another mistake.... i have replaced after someone pointed the error,by another wrong one... the 2N5551 also cannot do the job...it can face the voltage but not the power.
Another mistake in the schematic, the first VAS emitter resistance is not 50 ohms.... it is 560 ohms....this is what was designed and assembled in the working prototype...almost 500 miliwatts iddle is the power in that transistor..without signal.
So, as people have not the prototype, or an assembled circuit, only watching the schematic, found these errors and complained...... and me....by my side, having a working prototype, could not accept the amplifier was not working..that would explode or be damage.... was working.... and working for monthes long.
Some small adjustments are being made...first to make the schematic a good copy of the reality..also some small tuning will be made...i do not like the 25 kilohertz square wave...i think we can make it better....also the limiter adjustment resistances will have a trimpot to adjust clipping simetrically.
We still have a "more real" schematic,but will have small modifications..so..i is provisory only.
I have made tests with 3.5 ohms load...inductive+resistive load..and the amplifier survived, using only 5 pairs (this is the way prototype is) in the ouput... and because the supply i have used dropped the voltage to more or less 70V.
I believe it will work fine with reactive loads when using the 10 output pairs suggested...and soon i will test that...sadly will not be able to test with 3.5 ohms because my supply voltage drop.... as i will not have 80 volts..but i will be able to test with 8 ohms.
As i could not test to lower impedances.... and because of that i cannot guarantee the amplifier survival under these circunstances..under these conditions, them i would like to say the amplifier can work with 8 and 4 ohms only.
I have made some videos.... not only explaining these things, the main differences between the schematic and real life prototype, and some testings made.... i hope you enjoy.
Sorry by the bad image...i have two cameras..one has good video and other has good audio...i have not digital camera that has good audio and video.
Troyan amplifier is not guaranteed to work with speakers, or output impedances, lower than 4 ohms
Next post will have links to videos.
Dx unbeatable amplifiers; https://www.youtube.com/watch?v=u4tGBiqMnzQ
Old 14th August 2010, 06:35 AM   #222
Workhorse is online now Workhorse
Workhorse's Avatar
Hello Carlos,
Sad to hear that selenium is acquired by Harman now
Cheers for Troyan amplifier
Old 14th August 2010, 10:33 AM   #223
Default I almost have cried Kanwar.... very sad thing.....well.... this is
the new Global economy...... but Selenium was very traditional here....something very Brazilian.
Let it be...new world, ....new brands.
regards,
Carlos
Old 14th August 2010, 10:38 AM   #224
Default Here some videos about Troyan tests.
First video explain all that misunderstanding we had..... differences from real life amplifier and the prototype:
Sorry about video quality:
YouTube - Introduction - Troyan - errors being fixed in diagram
YouTube - 1 - Troyan test, set up presentation.
YouTube - 2 - Troyan test, stand by supply voltage
YouTube - 3 - Troyan supply voltage drop - 80 to 70V
YouTube - 4 - Troyan output, 37.5V RMS over 3.5 ohms
YouTube - 5 - Troyan test, conclusion
Enjoy!
regards,
Carlos
Old 14th August 2010, 11:06 AM   #225
Default This is the updated schematic and layout from Troyan amplifier
Thank you Alex mm by your help.
I intend to open a new thread.... builder's thread...for builders only, this way we gonna have only the needed informations.
This amplifier schematic, layout and so on will go to Greg Erskine pages too..but i want to refine it first...also i have not part's list and Greg will ask me the BOM..also adjustment instructions and other details.
In advance i want to check how much interest people have to build big amplifiers...this one may reach 650 watts each channel, unclipped, 4 ohms loads, with 80 plus 80 volts supply (huge one or SMPS one) and THD will be around 0.021% to 4 ohms.... and of course smaller to 8 ohms.
Building a stereo, then having two channels added.... 650W plus 650W will result in 1300 Watts total.... a strong amplifier.
Well..this is simulator specifications only..... to see some real thing you should watch the videos made.....with reality problems...supply with voltage drop.... poor builder that has only 10.000uf plus 10.000uf by 100 volts condensers..and so on...hehehehe...it is hard to obtain full power this way
We will go progressing stimulated by the interest...having huge interest the amplifier will be re-tuned for maximum performance (sonic)...and charts, informations and videos will be produced and published.
Let's see if there's something more to be fixed...i will inspect the prototype in details to check the schematic....to be sure they are the same.
regards,
Carlos
Old 14th August 2010, 11:15 AM   #226
Default Alex mm, Dx Corporation European Layout Laboratories
have made nice X Ray vision...but too much big.
Then i have splitted in two parts to show you... soon i will learn how to manipulat layers and will have images by myself.
This board made by Alexandru, looks alike the Enterprise Space Ship.... wonderfull..not nice!..just wonderfull!
Builders!....please, write me and i will upload to your email adress the full size pdf file:
Use direct email....forum PM cannot attach images, goto:
carlos.eugenio1951@yahoo.com
regards,
Carlos
Old 14th August 2010, 11:43 AM   #227
Default These pictures shows you the VAS stages...the way it was since the first day
the Troyan was built, and that was there working till yesterday when i have removed them and substituted by MJE15034 (from Evette - Canadá).
I had colector lead broken in the transistor case..could not solder anymore... this is the main reason i use to cut leads short..this is to avoid "mechanicall advantage"..... Alavanca (lever) in my language, to avoid broke the lead in a easy way.
regards,
Carlos
Old 15th August 2010, 11:51 AM   #228
Default Gladly i am receiving people in my direct email adress
People that intend to build the amplifier...this Troyan.
I feel happy, of course, i am human..... i have feelings...all the good and bad feeling we all have.... but, i have to inform things about:
- The amplifier was tested....passed!....but the board was not tested!
- The amplifier is an average performer...alike hundreds of others you can find..it have anything special in sonics....a very good sound.... a very good performance, high fidelity,but not awsome..just good and fair....does not have superior sound alike Blameless or Dx Blame ST...it is a power plant.
Also, despite i have tested real life, some good engineers had worries about the amplifier..some of them said would explode, damage, cause harm results...some of them asked moderators to close the thread, to vaporize the design and desintegrate the whole thing...so...the amplifier is under suspectious in the Academic group.
I felt reliable, worked for hundreds hours...and i cannot understand (really) their worries..maybe some mistakes i have made in the schematics.
I am a self made man..that learned in this same forum... someone that have practice and not too much theories..i have made dozen courses, long studies in Brazil and in outside Brazil...but i have not the degree..so...not too much addicted to calculations... i have perceived we have to adjust things to real life and i felt good to be in the "production line" instead of the design department...i am creating in the workbench...burning fingers...if i have doubts will burn, will explode, then i submit to test, to torture, to see if will happens or not.
The one made the layout is a friend, a cooperator in the Big Corporation of high quality amplifiers, the Dx Corporation, the Audio amplifiers Union.... we are a virtual group of builders... associated inside the virtual corporation of freak fanatics..... Alexandru is not my employee...he belongs to the virtual Corp. that has not a boss, has a representative chaiman wich is "Uncle Charlie".
Alexandru made the board...the layout..he has the gerber files or can have them..it is up to him publish or not the gerber files...i really do not mind he publish or not....i want him free and happy to do whatever he wants to do..he is a cooperator, not my employee.
The man, Alexandru, or Alexmm, is very good, he have never made a mistake..all his boards had no revision because of him...revisions where made because uncle charlie making foolishes.... i think his board is fine...but, Alex is human..he can make mistakes alike all humans does.
So..you will be board layout beta testers..... it think Alex have not build and i am not sure if he intend to do that...i think not..he have not all that free time...so..i cannot guarantee if we may have a copper line missed or not in that board.
Build this layout under your own risk..i can guarantee the circuit, but i cannot do the same for this board..untested!
Pictures shows a 250 watts heatsink, used in a Television transmitter, the one had 250 watts consumption continuously.... this heatsink is too much small to one channel, at least two of them should be used, and each one of them with their own fan blower operating with 8 volts DC not to produce too much noise.... this one overheated to almost 80 degrées celsius while i had an enormous fan blowing air to it...as a 60 centimeters diameter high powered fan...this one is too much small!
regards,
Carlos
Old 15th August 2010, 12:26 PM   #229
Default The heatsink i suggest to each channel should be big as this one
Then you will be able to use full power without troubles...but use a low speed fan blower (8 volts supply, an LM7808 may help to reduce from 12 to 16V)
2 of these ones to each channel..one for NPN and other for PNP...or equivalent to this area exposed to the air..do not worry about thickness, it just produce a delay in the heat transference..the heat exchange is made by area exposed to the air.
The images have dimensions in the place of identification names.
This one proved as not good enougth using only one to a single channel...so, i think 2 units, using fan blower may be good..or the equivalent in size..i am not absolutelly sure...but i can sniff that because of long time practice and i really think it will fit.
I will study, once again, fuses values and supply condenser values..will inform you as soon as i see several folks interested.
regards,
Carlos
Old 15th August 2010, 12:33 PM   #230
wahab is offline wahab  Algeria
The protection act only by limiting the current to 1.5 A per power
device whatever the output voltage.
R30/31 resistors are useless since they are not correctly
settled for the circuit to provide a I/V protection...
The VAS is not protected if ever the output stage
limiting current circuit start to conduct...
Dx Troyan, a 650 watts channel amplifier.Hide this!Advertise here!
zeta 500 watts n-channel amp pcb need ashokavarthanan Solid State 0 1st October 2007 04:10 PM
Fender/Sunn SA6520P 6 channel powered mixer 520 watts dhardinger Instruments and Amps 0 13th April 2007 12:10 AM
