Old 19th April 2010, 08:52 AM   #1
Default Bridged mode for C-Audio RA 3001
Hello all
First post here and just needing a little advice regarding using this amplifier (400w @ 8ohm) in bridge mode.
I connected this amp to a single Electrovoice ZX5 (8 ohm 600w) as a monitor and switched it to bridge mode which should give 1200w.
Sending from the desk into channel A and connecting the amp to the speaker on channel A, I noticed both channels were registering on the amps meters.
Just wondering if that's normal and my connections were right.
Is the wattage ratio acceptable as well (it sounded fine and the amp volume control was driven on 6 out of 10) ?
many thanks for any help
Lyn
FS: BK Precision 3001 Handheld audio signal generator davidhs Swap Meet 3 6th May 2007 06:18 AM
LM4780 sounds murky in bridged mode alexcd Chip Amps 6 9th October 2006 07:52 PM
LM4780 Bridged mode and single supply ringo42 Chip Amps 1 12th July 2006 09:58 PM
Dual differential mode inductors in a bridged output lowpass filter BWRX Class D 3 17th November 2005 03:39 PM
schematics of Rotel RA-971mk11 / RA-971 digitaldiablo Solid State 0 12th June 2003 04:03 PM
Page generated in 0.06644 seconds (65.94% PHP - 34.06% MySQL) with 10 queries
