Old 16th April 2010, 08:16 PM   #1
larryB is offline larryB  Canada
Default Rate and comment my poweramp design
This is a power amp I have in mind , plz do not laugh yes I work things out brute force with my scope and breadboard , I am not a sim guy .
Here is the design I have in mind , input will be a sine wave about 2 V p-p anywhere from 300 hz to 20 khz . I am using op amps as phase splitters to drive the mosfets . This is what I believe to be a class A transformer coupled push-pull modified by me .
Mosfet will probably be a class-d lateral mosfet with 900 pf input capacitance and 12 , still choosing . Op amp is the lm8261 , wich is just perfect for my application from the looks of it .
So I am gonna be running 2 x mosfets per amp , so 1800 pf input , yes Its strange i know .
Transformer secondary is floating , load might be anything from capacitive to inductive , put an x value , I am not aiming for maximum power in 8 ohms or w/e , this can go from a couple mA to large amps , most likely a slightly reactive load load ... I wont go beyond 6 amps on the secondary side .
Transformer will be either 1:1 or 1:2 step up audio range type .
Plz tell me if this is good , is the biasing resistors good like this ? Do I understand things correctly ?
Old 16th April 2010, 10:48 PM   #2
nigelwright7557's Avatar
It will run in class b and have crossover distortion as it stands.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 16th April 2010, 11:51 PM   #3
How can I make this same design run in pure class A , isnt the resistor biasing making this class A
Old 16th April 2010, 11:52 PM   #4
How can I make this same design run class A , I tought the resistors were doing that ?
Old 18th April 2010, 07:45 AM   #5
ontoaba is offline ontoaba  Indonesia
ontoaba's Avatar
No, the opamp forcing the resistor for do nothing.
Old 18th April 2010, 10:42 AM   #6
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
larryB;
Look at your design again.
With 0 Volts at the input your Opamps will try to set their outputs at 0 Volt.
Result: The Opamps will just draw Current through the resistors connected to +15 Volts until output is 0 Volt (as on the input).
You need to add a biasing circuit between the Opamp outputs and the output Fets......
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com
Please rate this psu design Groundloops Power Supplies 8 15th October 2007 09:46 PM
Comment on my DIY Sub Design htgeek Subwoofers 22 8th April 2005 05:26 AM
Please comment this design promise Solid State 0 20th January 2005 05:25 AM
comment on this design, please. JAZZ2250 Tubes / Valves 6 24th November 2002 10:45 PM
howzabout this for a poweramp design? mlloyd1 Solid State 4 14th May 2002 09:38 AM
Page generated in 0.09177 seconds (74.51% PHP - 25.49% MySQL) with 11 queries
