Hi, what output stage you consider optimal or best for a low power amplifier (<20W)?
Distorsion / Sound / Thermal Estability / Zout / optimal Iq / . . . figure2 need 2 preset (R30/R31) to set the same Iq on power transistor?
- Music by John Williams - |
#2 |
The first one, which is rather a standard Darlington configuration. The second one is for low power output and you'll need a lot of changes to adopt it for 20W output.
The first one may oscillate dependent on the choice of output transistors, layout, VAS, characteristics of the speaker and cable connected, etc. So, watch out! Have fun! Regards, Satoru |
#3 |
The only changes you will make to the second one is to use proper outputs and increase the the current sources. I have seen commercial amps with 100W output using the same basic circuit with more output pairs.
| Help with input stage driver for EL84 output stage | AudioGeek | Tubes / Valves | 2 | 20th March 2010 01:38 AM |
| SRRP Output stage. Calculating power output. | Cassiel | Tubes / Valves | 1 | 1st March 2010 02:38 AM |
| 3C24 in a SE output stage - output transformer impedance recommendation !!! | aldovan | Tubes / Valves | 15 | 6th September 2008 10:18 AM |
| Output stage biasing, with the driver stage | andrew_whitham | Tubes / Valves | 0 | 19th May 2007 11:14 AM |
| Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 | freddymac406 | Tubes / Valves | 3 | 21st April 2007 06:15 PM |
| Page generated in 0.10506 seconds (61.92% PHP - 38.08% MySQL) with 11 queries |
