Edwin 20 watt (Elektor 1970 - May)
Old 16th April 2010, 09:43 PM   #11
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
Originally Posted by mjf View Post
QUOTE=tiefbassuebertr BTW this amp was my first amplifier project (arround 1976). It was a amp kit from Oppermann electronic include PCB
hello.
found something.........
Exactly - the 20W EDWIN
Unfortunately it was stolen from me during the time in the military (the closed locker, where the amp was stored at the weekend, was screwed from behind). So I cannot make a soundcheck and comparable test with today's amp projects
Apexaudio: this is a normal Class AB amp; R9 can replace with a variable resistor.
Curious is the not presently emitter resistor, so that the cross current through T1 was only the base input current of T2 (only uA aera - hugh design failure and main reason for bad sound !!!).
Old 16th April 2010, 11:14 PM   #12
wahab is offline wahab  Algeria
Not a big loss, anyway...
This elektor amp is a complete failure on its own.
Fortunately, they much improved their designs the
following years..
Old 16th April 2010, 11:31 PM   #13
Bonsai is offline Bonsai  Europe
Very interesting to look at those old designs. Anyone got a copy of the Elektor 'Equa' amplifier. I looked on the web - no luck. Its from about 1975 or 1976.
thanks
Old 16th April 2010, 11:43 PM   #14
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
thanks
I have 'Equa' in JPG format, but not on English (Serbian)
Old 17th April 2010, 07:49 AM   #15
Elvee is offline Elvee  Belgium
Elvee's Avatar
following years..
Indeed.
This kind of amplifier is basically a square wheel made to (sort of) work.
But when you look into the details, you understand immediately they're hopelessly flawed.
Here is the residue appearing between the inputs of the diff amp:
It says more than a thousand words.
Old 17th April 2010, 07:56 AM   #16
mjf is offline mjf  Austria
hello.
i think this was the equa amp.......(i am not shure)
(could be published in elektor dezember 1972)
Old 17th April 2010, 09:15 AM   #17
steph_tsf is offline steph_tsf  Belgium
steph_tsf's Avatar
Originally Posted by Elvee View Post
Indeed. This kind of amplifier is basically a square wheel made to (sort of) work. But when you look into the details, you understand immediately they're hopelessly flawed. Here is the residue appearing between the inputs of the diff amp (see waveform previous post): it says more than a thousand words.
Hello, it is not a flaw, it is a feature ! By the way, I am now including the test you've done (voltage on the diff amp), as routine health check. Thanks ! I agree with you that if music is supposed to be delivered by such an amplifier, the tiny variations around the zero may be ignored, masked, erased while the amp is so heavily busy, eliminating the crossover distorsion. Kind of window opening and closing at each crossing. One may learn something, listening to such "flawed" amp ... Don't you think ?
Old 17th April 2010, 09:39 AM   #18
Originally Posted by steph_tsf View Post
Hello, it is not a flaw, it is a feature ! One may learn something, listening to such "flawed" amp ..
A feature ?...Perhaps for a guitar amp overdrive function...
Old 17th April 2010, 09:59 AM   #19
following years..
Bonsai post #13:
From the view of the real value here of course not, but from the view of the sentimental value, since even a lot of work has been invested for the enclosure resp. cabinet (also a FM Stereo Kit (FD1A/uA703/CA3189/MC1310P) was integrated).
From this amp I have win an auction from the concerning elektor magazine last year. I have build this amp, but I get an oscillator. The reason is the topology of the output stage. Also in the Pspice simulaion I observe the same oscillation effect
The output stage should be an improved topology (with respect to the symmetry between the positive and half negative half) compared with those from the Quad 303.
Until this day I haven't found a satisfy solution to remove the reason for the oscillation (except the use of the normal two stage buffer, i. e. darlington for the pos. half and sziklai darlington for the neg. half
Old 17th April 2010, 10:12 AM   #20
Everything is flawed , from the input to the output..
To make it work correctly, here s some mods to implement,
but still, the amp would remain a mediocre one, although
not the worse one either..
Edwin 20 watt (Elektor 1970 - May)Hide this!Advertise here!
pass 20 watt class a amp_guy Pass Labs 14 9th January 2015 01:04 AM
20 Watt Class A amplifier JOE DIRTŪ Solid State 8 31st January 2012 11:41 PM
schematic for 20 watt lme49830 needed mcmahon48 Chip Amps 9 14th August 2008 04:51 AM
20 Watt SE. I had found it. Hojvaelde Tubes / Valves 12 10th April 2006 09:04 AM
Klasse A-versterker van 20 Watt Jay Solid State 26 25th September 2005 06:04 AM
