My new preamp, an Electrocompaniet EC-1, have one noisy phono channel.
Not hum, but cracklings... In order to solve this problem, I would like to find schematics, diagrams, ... Of course, I asked that to Electrocompaniet Norway, but without success. And I am not astonished by this no reply ; all companies are doing so, except AUDIO RESEARCH !!! Perhaps You are able to provide help ? I hope Raymond My EC-1 :
#2 |
You could ask Mr. Abrahamsen who started EC, and now runs his own company Abrahamsen Audio.
Abrahamsen Audio | H e a r i n g i s B e l i e v i n g |
#3 |
hello.
have you tried out the search button (on the end of this site)? i think there are some threads about electrocompaniet preamps.........perhaps this can help. greetings |
#4 |
If you receive no circuit diagram, my guess is that the problem may be an electrolytic capacitor in the direct signal path or possibly a 'dry' solder joint.
#5 |
Halols, mjf and Gorgy, THANK to You !!
- I will try today or tomorrow to contact sir Abrahamsen but without good hopes because my English is a bit poor ( if I was Norwegian like you it will be more easier with phone to get a nice reply !! ). - on DiyAudio, nothing appear about EC-1 ; only one other guy, like me, is trying to get schematics. - Of course, I verified before all electrolytic C and changed all these out of specifications ( around 16 C 22µF/63v were so ! ) but no amelioration ; in addition with a magnifying glass, no dry solder found. This is why I am searching then schematics for understanding circuitry ! Raymond |
#6 |
if i understand correctly it is only one channel of the phoneamp that is crackling.......
annother reason for that can be a bad contact........the source switch,can be cleaned with a contact spray or so........... greets |
#7 |
have you checking this sources?
schematic download sites i have found Electrocompaniet EC1 help requested http://www.audiocircuit.com/index.php?c=ELC&m=EC-1 |
#8 | |
But alas, nothing on them abour EC-1 preamp. Raymond |
#9 | |
Crackling become visible ( with oscilloscope ) in the middle of phono stage ( the right channel only ). Then, no problem with source switch, volume & balance potentiometers. In this case, only diagram can help me Raymond |
#10 |
hello.
can you give a little pressure (with your fingertip) on the bad channel so that the pcb is a little "bent trough"............if then the crackling changes it should be a bad soldering point or hairrent or bad contact.......... |
| yamaha ec-1 crossover | audiomachines | Solid State | 1 | 26th January 2008 11:27 PM |
| who build EC AMP | john-china | Solid State | 5 | 31st December 2007 11:07 PM |
| Nakamichi ec-100 | tade | Parts | 0 | 3rd March 2006 08:59 PM |
| FF vs EC | Leolabs | Solid State | 0 | 23rd February 2005 06:37 AM |
| Electrocompaniet Orig 2 Channel Amp & Preamp | mozfet | Swap Meet | 1 | 13th January 2003 10:32 AM |
| Page generated in 0.10648 seconds (79.42% PHP - 20.58% MySQL) with 10 queries |
