Dear every one!
Please tell me the difference in the transistor 2SA1216/2SC2922 and 2SA1295/ 2SC3264. I want to use them to DIY some high quality amplifier. In the datasheet, they seem identical except for differences in voltage, 2SA1295/3264 have withstand voltages ( max 230Volt ) greater than 2SA1216/2922 ( max 180Volt ), but my amplifier running under +/-70VDC. For the best performance please guide me choose the one? Is the 2SA1295/3264 are low price of 2SA1216/2922 version? I will oder from Profusionplc: 2SA1216Y Technical Specification: please see picture Thanks and best regards Good day!
RFT 7186 |
#2 |
In Switching mode, 2SA1216/C2922 have Characteristics better than A1295/C3264. It has Ton, Tstg, Tr and impedance is lower, double Colecter current. It mean speed, dynamic and dumping factor in curcuit is better...
RFT 7186 |
#3 |
Comparing 2sa1216 to 2sa1295, the first one has a better current gain linearity.
Hfe is flat untill 5A. Ft is a bit higher too. Though, I have built an amp using 5 pairs of 3264/1295 of which i am very pleased. Last edited by bobodioulasso; 15th April 2010 at 10:01 AM. |
#4 |
Hey don't dismiss their thermal resistant.
A1295 has a bit better thermal resistant than A1216. Also there already A1494 with much better thermal resistant. It is SANKEN superiority. It affect greatly on its reliability. |
#5 |
I have burned some of them, 2SC2922 and 2SC3264.
To me, no doubts, the best one is 2SC2922. regards, Carlos
Try to build an amplifier folks ... it is pure adrenaline! |
#6 | |
which design did you use? There are very few designs out there with 5 pairs of Sanken 2SA1295/2SC3264. Rotel RB1090 is one of them. Good amp. Unfortunately many transistors in this amp are obsolete, which means, very hard to find and expensive. |
#7 |
You are right.
I used a lme49810 driver chip and the RB 1090 output stage + one pair, without the predrivers. |
#8 |
thanks for all regards!
Sori i don't find "EDIT YOUR POST" so three picture is overlap. Dear HighTec, Rotel RB1090 seem has dumping factor 1000, very
RFT 7186 |
#9 |
#10 |
This is my schematic
| Class A amplifier with 2SC3264 and 2SA1295 | gili_flash | Solid State | 4 | 15th April 2010 03:06 PM |
| sunken 2SA1216/2SC2922 | space2000 | Solid State | 7 | 8th April 2008 11:25 PM |
| ### need spice help by 2SC2922/2SA1216 | small_boy | Solid State | 2 | 5th January 2008 12:47 PM |
| small 2SA1216+2SC2922 ? | lumanauw | Parts | 3 | 4th September 2007 05:36 PM |
| Sanken 2SA1216 and 2SC2922 (again) | len_scanlan | Swap Meet | 0 | 29th March 2007 08:34 PM |
| Page generated in 0.11589 seconds (80.94% PHP - 19.06% MySQL) with 11 queries |
